Coilovers for PASM
I have a 2009 997.2 CS2 with PASM and is thinking of putting in coilovers. Appreciate any suggestions as to the correct coilovers that will work with PASM.
I think Bilstein B8 or B16 (B8s but adjustable) Damptronics are the only realistic options. There are also some Tractive units that are around $7k a set.
If you're not doing it for the lowering, the TPC Racing DSC module performs miracles with the stock suspension according to almost everyone.
Premium Sponsor
Like others have suggested:
1. Bilstein B16 coilover kit- good value for the price range when they are available, been unavailable since last Fall. The B16 spring are on the soft side but the springs can be swapped if stiffer springs are desired. In order to be at this price range B16 are intended for users to transfer their existing front and rear rubber top mounts. By now most of rubber top mounts on 997's have aged so I'd recommend fresh rubber mounts or upgrade to GT3 type monoball to mounts to improve performance. Reaction time to command ~100 milliseconds.
2. Buy new or used GT3 coilovers, here you have the option for the following variations 997.1 GT3, 997.2 GT3, RS, 4.0, GT2, GT2RS. The variations allow the user to mimic the damping feel of a certain GT model. These parts are modular, I make the adapter parts to allow for bolt-on fit on any 997(non-GT). GT coilovers can be installed with monoball top mounts or I have adapters to fit original rubber mounts. And spring rates can be custom selected from GT model or aftermarket. Reaction time to command ~100 milliseconds.
3 .Tractive coilover kit, top-of-the-line, motorsport quality, ultra advanced double spool valve design, wide enough damping range to be more comfortable than stock at the low end of the range while race car level at high end of the range, included front & rear monoball top mounts and spring rate of your choice. Reaction time to command ~6 milliseconds, responds to full command during mid-stroke.
With any one of the options above having DSC Sport controller allows the user to get the most comfort, performance, and versatility out of.
PCA National Instructor
TPC Racing stats:
2023 Porsche Sprint Challenge 992 Cup Am Champion
2023 Porsche Sprint Challenge GT4 Pro-Am Team Champion
2022 Porsche Sprint Challenge 992 Cup & 991 Cup Champion
2020 IMSA GT3 Cup Challenge 2nd Championship
2018 IMSA GT3 Cup Challenge 2nd Championship
2016 IMSA GT3 Cup Challenge Champion
2013 IMSA GT3 Cup Challenge Champion
2006 Rolex-24 @ Daytona GT Champion
2004 Grand-Am SGS Class Champion
TPC Racing stats:
kayha12 (01-01-2022)
As an FYI I was also looking for a PASM compatible coilover and was leaning towards Bilstein. They are and have been back ordered for some time. Rumor has it production starts again as soon as mid August, but I feel at that time they will have a lot of backed up orders they need to fulfill. My shocks are a little tired so I found a more immediate solution. I ended up with Ohlins R&T and will be deleting PASM solely because of the great reviews read here and what seems to be easy adjustability.
Best of luck in your search!
