Does anyone have experience with these?
When I bought my 2009 C2, the original owner had changed the stock wheels to 19" F/R. Nice but rear tire wear is proving to be a bitch, specially on the inside.
I've been looking a this product a means to "dial-in" the camber a bit better. So if anyone has had experience with these in particular, please give me your thoughts and experiences. http://meganracing.com/mrs-pc-0410.html
Here's picture of my car with the wheels:
I personally wouldnt go swapping out links without first getting the car properly aligned using your stock hardware. There's no reason you cant rectify that issue with alignment changes. Many/most of us have cars that came with 19s. Some are running wider 19x12" in the rear. Others 20x11 or 20x12 too. I have zero issues with inner tire wear on 19x11 305/30 in the rears.
Mike
Mike
Stock alignment = Inner wear.
Decide if you want best handling or best mileage. Talk to a good mechanic who will volunteer to ask you about your driving habits and expectations before he does the work (note the words volunteer and before).
Toe in is a bigger problem than camber regarding inner wear, and small changes make big differences.
Lots of previous posts on this topic, but since search isn't even an option on my phone I'll leave that to others.
No issues with inner tire wear here.. running 19x12 325/30 for the last couple years. Should be able to sort it with stock hardware.
Stock hardware can give you adjustment needed to get the longevity of your rear tires, but you will sacrifice cornering. I think the rear camber on my base 997.2 is -1.5. I have heard others going to -1.0 and that has worn the tire almost perfectly. Just know it will still somewhat wear on the inside edge.
I have megan racing toe links on my 986 boxster due to extensive lowering. They work fine, and were dirt cheap in comparison to other choices, but they are also heavy as hell. I'd buy them again or make my own.
I'd get a good alignment before you start looking to swap parts out.
