997.2 service
997.2 service
September will be 3 years since I’ve purchased my c4s with 8800 miles, it now has 23k miles. Only thing I’ve done as far as maintenance was oil changes every 4-5k miles, tires, and brake fluid flush. I actually had 2 highly respected guys tell me my mileage is so low it’s not critical to replace PDK fluid. I understand that’s highly debateable but next week I’m having my Porsche Indy go through whole car since it is almost 10 years old and I’m over for most things maintenance wise in years but not in miles. The car runs like a beast and i have has no issues at all with it.
Here’s my list, should I add anything??
AWD controller fluid
PDK clutch oil fluid (pan filter if needed)
Plugs ?
Brake fluid flush
Replace Tire sealant ?
check all belts
Pollen filter
Check Wheel alignment
car has 2” gundo, Billyboat Center, softronic ECU, fabspeed dual intake, h and R Springs , wheel spacers
Plugs ?
Brake fluid flush
check all belts
Pollen filter
I would have a look at the date code for the tires if you have not changed them. I am on the fence on plugs, as I bought without service records and I am pretty sure nobody ever went near them, so I am curious to hear responses (age or mileage question).
Tires all changed at 14k
Plugs 40k or 4 years per Porsche. Changed my 2010s at 23,000 in November 17. Did not know if they had been changed before purchasing in 16. Really glad I did as they were much dirtier than I would have thought and I noticed the difference immediately.
