997 Chipped Gear
Old May 30, 2018 | 01:20 PM
John Carter's Avatar
John Carter
4th Gear
Default 997 Chipped Gear
Hey Guys,
Totally new to this forum thing but I wanted to get some outside opinions on an issue I'm having with my 997 as I can't find anything else online about my situation. I've been driving a 2006 997 for about 5 years now and it currently has 92,000 miles on it. I've had all my service done by a certified Porsche mechanic that is well known in my area. I don't know a whole lot about the mechanics of cars but my last repair ~89,000 miles was a clutch replacement.
Since the clutch replacement about 7 months ago, the car has been fine but about a month ago I got in the car one morning and the 1st gear was making a clicking sound (ONLY 1st gear). My Porsche guy took a look at it and said the first gear is chipped and that the noise I am hearing is the chipped piece. He recommends not using 1st gear much at all and starting the car in 2nd gear when possible. I'm worried this isn't good for the car and I would like your opinions on what I should do; I don't want to burn up my new clutch or put unnecessary wear on anything else. I've never heard of this happening before and I'm curious if anyone else has. My mechanic says the transmission needs to be replaced so I'm looking at a $3,000-$4,000 transmission plus labor on top of that. Any advice is greatly appreciated. Thanks in advance!
Old May 30, 2018 | 02:07 PM
cosm3os's Avatar
cosm3os
Not really hurting the car to start in 2d, but I'd be concerned about where that chip will travel . . . .
Old May 30, 2018 | 02:13 PM
DesmoSD's Avatar
DesmoSD
I'm not sure if your situation is similar if it's the pressure plate that is chipped but when is the clicking sound occurring? Is it when you press the pedal or when you put the shifter into 1st?
TheBruce post #21
https://rennlist.com/forums/997-foru...ifespan-2.html
4Driver4's Avatar
4Driver4
A very small pit or scratch or chip can make a lot of noise. I'd just drive it or fix it, nothing in between.
Old May 30, 2018 | 02:43 PM
John Carter
4th Gear
TheBruce post #21
It's when I press the pedal. 1st gear only.
Old May 30, 2018 | 02:46 PM
GTgears's Avatar
GTgears
Basic Sponsor
So he already has taken apart your gearbox? Or is that just a WAG he's making?
Old May 30, 2018 | 04:48 PM
John Carter
4th Gear
He took it apart.
Old May 30, 2018 | 07:24 PM
GTgears's Avatar
GTgears
Basic Sponsor
Since you're already in for that labor, I would say get a new mainshaft and let him finish the job. That will get you fresh dog teeth on 2nd gear at the same time and you shouldn't ever need to worry about your gearbox again. In the business we consider a "good used" gearbox a core in need of building regardless of miles or claimed history. Trust nothing you can't see directly. You are better of getting your own fixed properly than picking up someone else's problem child.
Old May 31, 2018 | 01:03 PM
John Carter
4th Gear
Thanks for all the help everyone!
Old May 31, 2018 | 05:30 PM
bimmer81's Avatar
bimmer81
You have pm
