Sticky radio knobs
Sticky radio *****
hello all,
is is there a proper was to clean the ***** on the radio?
they seem to have become sticky to the touch.
Thanks in advance
mike
Thanks in advance
mike
The stickiness is from plasticizers oozing out of the polymer. Whoever specced them effed up on the materials of compatibility. As noted above, replace them.
2 weeks ago, I was driving my GTS, then I touched my radio **** and it is so sticky. But nothing is in my fingers when I look at it. i thought since it just came from the dealer that the mechanic used dirty fingers. Then I realized the sticky radio *****. Thats what happens when they leave the car under the sun.
Try cleaning them first. I wrote some tips with photos here:
https://rennlist.com/forums/showpost...&postcount=138
Note that to remove the 997.1 ***** you can just pull them out. The 997.2 ***** are different and you need to remove a cap to get access to T-6 torx screws.
nearmiss (07-26-2020)
Rennlist software not showing the love for k-****?
$20 seems a little steep. Given that this issue has existed forever, I'm surprised we don't have aftermarket ones for half the price. Maybe I shouldn't have sold my spare radio.
Really? 20 bucks is stretching the household budget? Why would the aftermarket come up with an alternative to a 20 oem part?
If I'm not mistaken, there are lots of aftermarket products that are replacements for sub $20 parts. It's probably a volume issue (no pun intended).
I seldom look at $$$ savings, always percent and if there's money to be saved then I'm all over it.
ElectricChair (07-26-2020)
Did the same, baby wipe and 10mins...cheap and easy.
TheTorch (07-26-2020)
And the same thing happens in a few months. Clean your old oneswith hand sanitizer and they will look new and be permanently fixed. I just sent new ones back that came with my new climate control switches. After comparing them and then realizing they would get sticky again I re-cleaned mine and they are perfect and will not get sticky again; sent the old "new" ones back and saved 26$ and will not have to deal with them again.
