tail lights - front section loose
Old 05-25-2018, 05:55 AM
Gptoyz
Gptoyz's Avatar
Default tail lights - front section loose
Just got the car back from the shop and the tail light gap on one side was a bit odd, so I popped the trunk and adjusted.
I noticed that the forward section of the tail light was loose.
I thought at first they didn't install the tail lights back together properly so I checked both sides but they were slotted into the forward mount and the mount was tight.
what else can it be?
Old 05-26-2018, 09:58 AM
Petza914
Petza914's Avatar
Received 6,188 Likes on 3,945 Posts
I don't know, that's how they attach. You get the front clip in then the rear at the decklid, though there is some adjustability at the rear to pivot the light up and down with the 2 screws to achieve the correct bumper and fender spacing. If the problem is at the front then either the mount/slot on the light has a problem or the mount on the body has a problem.
Old 05-26-2018, 10:13 AM
cosm3os
cosm3os's Avatar
Reinstall it. They can seem to be in, but aren't (and then they come flying off in T7 at GingerMan Raceway).
Old 05-26-2018, 12:22 PM
Gptoyz
Gptoyz's Avatar
Thanks guys I'm going to give it a go
Does the front slot need to be tightened or loosened during removal or install
Or is it only the rear that looks them down?
Old 05-26-2018, 12:30 PM
Petza914
Petza914's Avatar
Only the rear. The front horseshoe on the light assembly just slides over the round disc on the body.
Quick Reply: tail lights - front section loose
