Video review of the Foxwell NT510 with Porsche software...
#46
Thanks andy93si, that’s what I needed to know
#47
Andy93si, on getting your right mirror to tilt down when you place your car (I have a manual transmission) in reverse I think that can be set with the instructions in your owners manual. If I’m not mistaken I did this on all three of my P cars when I first bought them
#48
Does this thing program the passenger mirror to tilt down when in reverse? This feature seemed to be linked to my PCM, and it stopped working when I swapped out my PCM.
#49
Just received my NT520 with the latest update. So far here's what I found after playing with it for 10 mins on my 09 997.2 C2S.
-Cannot reset oil light
-All blanks in over rev report
-DME total distance is listed as "miles" but displayed in kilometers
-Successfully programmed the side marker as turn signal
Would like to still do one touch pass window and remote open/close. Appreciate if someone could point out what needs to be changed. Also, looks like you can make changes to the Steering Control Unit for those that swap their units to the newer ones in order to make the 997.2 steering wheels function properly.
#50
- Passenger door
- Close comfort:on/enable
- Open comfort:on/enable
- Driver door
- PAS
- comfort functions
- comfort function window:on/enable
- comfort via radio remote control:on/enable
- comfort functions
#52
#55
#58
Thanks for that tip. I don't have the PCM2.1 manual for my car and I can't find anything in the PCM menus relating to the memory. I'm really not even sure if my car has memory, as I am missing the memory position buttons on the drivers door and only have 1 key so I can't test with other keys. Yet I do have sport chrono and I thought that all sport chronos had the memory function. I'm trying to track down PCM2.1 manual now.
According to the owners manual your vehicle must be equipped with seat memory in order for the passenger side mirror to tilt down.
#60
For remote window open/close on 997.1 I did the following: This is from memory, if it doesn't work let me know and I'll check the car when I get home.
- Passenger door
- Close comfortn/enable
- Open comfortn/enable
- Driver door
- PAS
- comfort functions
- comfort function windown/enable
- comfort via radio remote controln/enable
- comfort functions
***Solved***
Apparently somehow drivers down and pass up defaulted to off so I just had once again reprogram to on. Problem solved.
