Transmission mount torque values
I'm replacing the transmission mount on my 997.2 with manual transmission. Can someone tell me the torque value for the bolts that thread through the mount with torx bolt on one end and a torx nut on the other end ? Also considering that its a high vibration anchor point, do I need to apply lock tight for this hold-down torx bolt and nut ? Thanks
The torque values on the transmission support bracket and transmission vessel are all 48 lbs. Note: don't forget to replace those little foam stoppers on either side of the mount. They do eliminate a little vibration at idle.
Im having trouble uploading the notes I put together in pdf for my clutch job I did a few months ago. If you need I can try again.
