Oil change done but forgot to change the oil filter ...
Old 04-28-2018, 10:28 PM
MagnusB
MagnusB's Avatar
Default Oil change done but forgot to change the oil filter ...
Oil change done but forgot to change the oil filter ... Now what do I do?
Empty it all out in a clean container?
Old 04-28-2018, 10:40 PM
bhvrdr
bhvrdr's Avatar
That should work. How many miles on the filter btw?
Old 04-28-2018, 10:42 PM
swingwing
swingwing's Avatar
Just change the filter. All you're going to lose is the oil in the filter housing, probably not even half a quart. Change filter, check level and top up if needed. What year is your car? If you've got a 997.2 the filter is up top and your oil loss will be nil.
Old 04-28-2018, 10:46 PM
bhvrdr
bhvrdr's Avatar
Judging by his avatar it is 997.1
Old 04-29-2018, 01:29 AM
Qwksnke
Qwksnke's Avatar
Originally Posted by swingwing
Just change the filter. All you're going to lose is the oil in the filter housing, probably not even half a quart. Change filter, check level and top up if needed.l.
This
Old 04-29-2018, 09:21 AM
Petza914
Petza914's Avatar
Received 6,171 Likes on 3,935 Posts
+1
I've pulled just the filter before and can confirm this is accurate info.
Quick Reply: Oil change done but forgot to change the oil filter ...
