which fuses go on with ignition
20. 07 porsche 911 (Targa 4S). LoJack just lefty but unplugged the aftermarket Alpine updated head unit. I need to put the "Blade" into an unused fuse slot.
https://rennlist.com/how-tos/a/porsc...diagram-376033
Here's the fuse box diagram. I believe if you're only using the fuse tap for the accessory wire, using a currently occupied slot is not a problem. My understanding is the accessory line is only sending a turn on signal to the head unit. I could be wrong. Good luck.
You can tell just by looking in the slot. If the female blade receiver is only present on the hot side and the other side is empty, that gives you an unused slot. Them put your volt meter on DC 20V with the red wire on the present metal piece in the hot side of the fuse panel and the black on the metal catch where the door closes. Fond one that shows 0 Volts, then cycle the ignition to the accessory position and if you see 12v, you've found a winner.
