Door sil clips
Door sil clips
I would like to remove my door sils for painting. Just wondering if anyone else has done this and the issues encountered with the clips that hold the door sils in place.
Any info would be appreciated
^ Clips?
Are you talking about the plastic/aluminum/carbon fiber door sills with model name on them?
THey are just double-sided sticky taped down.. In my experience, very hard to remove without destroying it. In my case, I was upgrading to the aluminum version, so I didn't care.
Or are you talking about the trim piece with the frunk switch panel on it? If so, that part uses 2 screws and then just lift up.
Ah.
https://rennlist.com/forums/997-foru...diy-below.html
Not exactly what you need, but lots of good info on side skirts..
