DIY Oil change 9A1 7.2 C2s
So, couldn't find in the diy section or via search engine, only saw the 7.1. Am i blind?
i would like to start doing them myself
Lots of oil arguments (vs Mobil 1) , how about a couple of recommendations (no debates, just a few)? besides Mobil 1, although thats what i've run in it by my inde for the last two and a half years.
Warm car 20 mins, i believe
Drain slippery stuff for 45 minutes min.
Remove filter (easy find)? haven't really looked, though i have a small lift i use for my part time track car (70 camaro ss/rs-ls)
Reinstall drain plug, 40 ft lbs ish?
7.5 litres?
recommendation's on filters?
Haven't thought about you-tube, maybe i'll try that later,
anyways, cheers, mike
7.5 litres?
Oil filter is on top, accessed through the engine cover. Right side, very easy to find. IIRC requires a 37mm socket, torque spec is printed on the filter cover. Very easy.
You guys are bad. Every time oil is mentioned it’s like a feeding frenzy.
I’ll wade in - anything from the Porsche approved list works - I use mostly Castrol Edge 0w40.
I’m a bit obsessive so I replace the drain plug and gasket at every oil change (5000 km) - cheap insurance.
Make sure you get the correct hex bit to remove the plug otherwise you’ll strip it.
When I torque the plug I work up to 35 ft lb from 20 ft lbs in 5 ft lb increments - I have this thing about aluminum - don’t want to mess up the pan.
Hence, "ish" lol. I 'd look it up if there were no replies, but since i'm paying to be here and untapping all of this righteous knowledge, what the hey i say....
And i looked / searched for all the oil wars, apparently they've all been taken down, probably by Mobil 1.
thanx, the basic info i was looking for. I've used mobil 1, red line, royal purple in my LS, i'm not really partial to any of them in that car as i beat the **** out of it and its a helluva lot cheaper to rebuild than this scapel.
thanx you, Youtube to the rescue once again, i'll watch it later on....
Its just an oil change, what could go wrong? Kinda like putting gas in the side filler of a 72. Or overfilling is no big. Or torque'n too 105....hehehe...
thanx gents, have a good eve, mike
Very helpful. The reset tool you showed at the end, either the durametric cable or the other one, can you elaborate a little more on that? That was one question i meant to ask in my first post, if there were any reset indicators required for this maintenance.
thanx
Just changed my oil put 8.2L in, marks full when warm. Make sure to use new aluminum crush washer and new rubber gasket for filter housing
I use a small syringe for removing the residue oil at filter base
Do we all have to reset the CPU with a Durametric? I guess thats my only question. Other than that, piece of cake imo...thanx
2009 C2 S 124K miles
I get my filters and crush washers from Pelican... I get the OEM filters, not Porsche. I also have a magnetic drain plug for maximum entertainment. Change every 5K with Mobil 1 from Walmart. Reset reminder with a Durametric. Drink Pilsner Urquell in mass quantities. I use about 1 quart every 3,5-5k miles depending...
Some information for fun:
https://rennlist.com/forums/997-foru...ent-issue.html
https://rennlist.com/forums/997-foru...icks-pics.html
https://rennlist.com/forums/997-foru...max-drain.html
https://rennlist.com/forums/997-foru...il-change.html
https://rennlist.com/forums/997-foru...evolution.html
Peace
Bruce in Philly
Peace
Bruce in Philly
So the consensus is pretty much if you want to do your own oil change, get a durametric for no "reminder lights", while the oil change is straight forward, the durametric is not. I went on their website and they run 279 for the basic one. Probably four oil changes would pay for it, not too mention it does other basic diagnostic work as well.
Peace
Bruce in Philly
Peace
Bruce in Philly
B- thought they didn't allow german cars into parking lot of wal-mart, you driving a 1976 ford econoline motorhome your not telling us about, to obtain access to said parking lot
C- thought you had to drink german beer while performing this, i'm an american drinking mexican beer while working on a german car with japanese wrenches made in china (thats where snap-on is right?), know wonder this is confusing
