PCM not working
Old Apr 2, 2018 | 04:49 PM
HermosaEd's Avatar
HermosaEd
Default PCM not working
PCM screen on my 06 997.1 C2S is not working. The screen turned on when I turned the iginition, but it is all scrambled like a tv with really bad reception. I switched off the car hoping it would reset, nothing. I turned off the radio hoping it would reset without any luck. Has anyone have this happened? Is there a quick easy fix for this?
I don't even want to look into replacing it because the car is an old car, but still very every bit of fun to drive. I rather save the funds for maintaining mechanical components, unless it will interfere with the car performance which I doubt would be the case. Thanks in advance for your inputs.
Old Apr 3, 2018 | 10:37 AM
Petza914's Avatar
Petza914
You can try pulling the 2 PCM fuses (maybe 9 & 10) or holding down the 3 button combination (something like 1,4,8) to force a reset. Sometimes that does it. Look up the correct fuses and button combination though.
Old Apr 3, 2018 | 11:15 AM
RNBM's Avatar
RNBM
I just fixed the same issue with my pcm. Had to replace the screen. I did it myself since, for around $300. Had spilt coffee onto the pcm. There is a you tube video on how to dismantle the pcm. I think there are a few small companies that will repair for around $500 to $600.
Old Apr 3, 2018 | 03:29 PM
mike cap's Avatar
mike cap
Becker in New Jersey will repair it if you pull it and ship to them. You can call them and see if they can give you a hint as to your issue. Google for info I think they’re in Somerset or something like that. Guy to talk to is Eddie.
Old Apr 3, 2018 | 03:41 PM
HermosaEd's Avatar
HermosaEd
I started the car this morning. Now it is working again without me doing anything to it. Should it happen again, I'll try the reset by pressing 1,4, and 8. I saw that same combo from a different thread.
Thanks so much for all your help.
