Sport Adaptive seats installation
I have a question and I'd really appreciate if someone can help me.
I bought a pair of used adaptive sport seats. After the installation, both seats are able to move only back and up/down. None of the other functions/buttons are working, and everything is connected as it should. I do have durametric pro but I couldn't find any option about coding or setup. Any ideas? Can the seats be completely dead? (motor dead?). Even if this is the case can I replace the motors from my existend standard sport seats?
To add on the above, the seats came without a module (under passenger's seat) and I used mine.
Thanks!
Thanks!
What seats are you coming from? If they are the 18 way electric ones, then from what I understand, to do a straight swap you would need to have memory seats currently in your car. Otherwise it will require some wiring.
this ^^
The seats I have already on the car are the "Comfort Seats" ones with memory/heat and (I believe) 12 positions. All the available connections on the new ones are connected to my existent ones.
I went from Comfort full power to Adaptive Sport plus and they were plug and play with everything working. What year is your car and what year did the seats come out of?
