Oil leak from top of PDK transmission
For 20 years, up until the 997.2, all cars had switch problems. So you have a lot of cars suffering a common problem that had an easy learning curve.
None of that applies to the PDK.
I suspect there would be an entrepreneur out there who would be advertising his/her services of there were enough problems to make it worthwhile.
OTOH, it seems like most reported problems have been electrical ... parts that may be heavily controlled and that may not be easily sourced.
Problem is there are no replacement parts available. I have found one shop in my area who claims they have repaired pdk transmissions. They basically buy non working pdk gearboxes and use them for parts. Few things like breather valves and some small parts are shared by other car gearboxes as well.
@Presto
Hello~
Since the pictures in your original post aren't showing up. Wondering if you still had those. Wanted something to compare with.
I noticed when I looked at mine the vent valve was cover in dirt crusted oil and evidence that there was some kind of leak for probably quite some time; and hey I didn't know it was blue color. Anyway, it was all down the driver's side of the trans but it wasn't like wet, just slightly greasy dirt build up when I somewhat cleaned it off. What I wiped off was like black dirt/crap with a hint of golden color, but maybe my eyes are just playing tricks on me.
Curious also to what you did. And maybe figure what my next steps would be.
I only looked at mine after getting a "Transmission temprature too high" message flash on; I was getting off the track after a cool down lap. Then the second it came up I had just finish a run at autocross. Both times the message came up and then disappeared within a minute or so. Grabbed codes off with Durametric but they were weird incomplete codes only 4 digits:
17F0 and 17F1 both say "Transmission overtemper" and that was it.
Posted the codes in another thread about PDK. Just curious if any of you guys might've run into this as well.
Thanks!
Hello~
Thanks!
Pictures uploaded below
https://imgur.com/a/RFpLCvq
All i did to fix the issue was drain the differential oil and refill the correct amount as per the owners manual. Previous owner had changed the oil and i think the tech working on it overfilled it.
I regularly check it and no leaks till date
Presto (08-29-2021)
Required for 991.1 on but not 997 as it does not have a transmission gear oil heat exchanger. However, it certainly does not hurt anything to do it anyway just to be on the safe side.
