Help identifying this shifter knob..
Old Jan 26, 2018 | 03:18 PM
Rodie's Avatar
Rodie
Default Help identifying this shifter ****..
... this **** was on a 997 I test drove but did not ultimately buy. That said, I'd like to find out where to get one as the one I did buy doesn't have it (and I liked it.)
Anyone recognize this? I think it is OEM but am not 100% sure. It has open slots immediately under the shifter and I liked the feel/look.
Thanks - Rodie
Old Jan 26, 2018 | 03:22 PM
Rodie's Avatar
Rodie
Old Jan 26, 2018 | 03:31 PM
DC911S's Avatar
DC911S
Its an OEM ****, check on the Suncoast website for it. It's a bit pricey if I remember right.
Old Jan 26, 2018 | 04:11 PM
nwGTS's Avatar
nwGTS
It's the **** from the optional X97 aluminum package. also included the handbrake lever
Old Jan 26, 2018 | 04:19 PM
shekmark's Avatar
shekmark
I have that package on my car. It looks cool but its freezing to the hand this time of year in NJ.
Old Jan 26, 2018 | 04:20 PM
shekmark's Avatar
shekmark
Forgot to add that mine has black leather inserts because I have black interior. .
Old Jan 26, 2018 | 04:42 PM
Rodie's Avatar
Rodie
shekmark -- if it's too cold for you and you'd like a stock **** -- let me know! The kit from Suncoast is $1K!?!
Old Jan 26, 2018 | 05:00 PM
Thefinn's Avatar
Thefinn
You can also get this from your local OPC
Old Jan 26, 2018 | 05:13 PM
kcheves's Avatar
kcheves
It’s called the X97 shifter, and is kind of a holy grail if you’re looking for a used one. Usually sold with an e-brake handle that is easily scratched.
Old Jan 26, 2018 | 05:43 PM
shekmark's Avatar
shekmark
Rodie, if your not in a rush I will likely switch it in spring. Not sure what I want yet. Kcheves is correct about light scratches. I don't wear them, but likely from rings. What color is your interior? Anyone know how to remove these *****? I think the brake handle just slides off.
Old Jan 26, 2018 | 05:44 PM
shekmark's Avatar
shekmark
BTW...1K dollars is ridiculous.
Old Jan 26, 2018 | 06:22 PM
DC911S's Avatar
DC911S
My thoughts too.
Old Jan 26, 2018 | 08:42 PM
kellen's Avatar
kellen
Installed the X97 into my car. The shifter comes off by rotating the clip after you pull up the leather shift boot. Note the gear selector is a solid piece of aluminum that goes an inch or so inside the handle vs others where the top is just plastic.
For the e brake, I swapped the whole mechanism. Wasn't too hard. I don't think you can just do the e break cover, think its the whole thing.
Old Jan 27, 2018 | 08:16 AM
shekmark's Avatar
shekmark
The reason I thought the brake handle just slid off was because the second time I drove the car to a restaurant, I went out to go home and could not release the emergency brake. I almost gave up and called a tow, then realized that the aluminum shell of the handle had slid up about half an inch and locked the lever button from using. I actually thought it might be some tricky anti-theft thing. I slid it back and all was well.
Old Jan 27, 2018 | 12:17 PM
Rodie's Avatar
Rodie
shekmark -- I'm in no rush, if you can and want to part with it put me first in line to make an offer to. I also have black interior..!!
