Magnetic drain plug for manual transmission - 997.2
I have a 2009 C2S (997.2) and it is a 6 speed manual. Last time I did a transmission oil change I found out that the drain plug is not magnetic. I searched everywhere and can't find a magnetic drain plug for the g97/05 transmission. Anybody on this forum found a suitable magnetic drain plug for the 997.2 ?
There is an inaccessible magnet in the transmission. However, I added a magnetic drain plug. It's exactly the same size as the oil drain and aluminum gasket. Use Mobilube PTX every 30,000 miles. Sunset Porsche has the best prices. About 3 liters for a change.
Do you know which magnetic drain plug you source it from ?
Ebay: https://www.ebay.com/itm/Porsche-911...item238f5e2373
One for the oil and one for the transmission drain. Strong magnet.
On my .1, the same magnetic plug for the oil pan fits the bottom hole of the transmission. I'm using the ones from LN Engineering.
does the transmission use the same aluminum washer as the engine oil drain plug ?
It does on mine, since I installed both together. I think every drain plug needs some form of crush/sealing washer whether it's the plastic/rubber encapsulated type or an aluminum or copper one. No problems with either of my cars that have the aluminum one installed.
Damn, son! When you niggle up a fastener, you don't mess around!
Top Tip: when working with hex heads, give the socket a little tap to make sure it's seated. Clean it out, too. Gunk gets in there and prevents the head from seating well.
Thanks. I just checked Pelican and the 2 washers have different part numbers and big price differential. The engine oil drain washer is 1.5mm thick at $2 and the transmission drain washer is 2mm at $18. Not sure how critical [or not] that 0.5mm thickness difference is.
http://www.drainplugmagnets.com/porsche.php
I recently bought both from AutohausAZ. Oil drain washer 90012310630 is $0.26. Transmission drain/fill plug washers (same for both) 99730180800 are $0.36 each. Pelican Parts is a great resource (books and tips) but IMO their parts prices are considerably higher. ECS Tuning, FCP Euro and AutohausAZ are my standard go-tos. Being new to Porsche and this forum I've seen lots of references to Suncoast, so will check them as well.
