Any recommendations on a new front bumper for a 997.1?
Turbo 997 bumper.
Bought mine used on ebay and, with some polishing, didn't have to repaint.
My first choice was the OE Aero, but factoring in the cost of the paint made this option a great deal. Definitely did not want to do aftermarket and deal with any fitment issues. It was nice that every thing fit exactly as expected.
Turbo 997 bumper.
Turbo 997 bumper.
Yes, turbo rear deck/wing as well. To keep costs down (and simplicity) I did a fixed wing and used the Durametric to turn the rear wing error off.
There was no issue with radiator, but I'll one day get around to painting the center area black behind the center grille. Also, I did purchase inner fender well liners but you should be able to use the original ones. I do have a small gap in the lower splash guard where the center radiator would fit, but have not seen any problems since I did the conversion over a year ago.
Everything fit as expected, however there were a few challenges along the way. The headlamp washer hoses had to lengthened and I also chose to cut off and solder the parking, fog and city light with new connectors to make assembly easier. To make the LED turn signals work, it did require making the correct Durametric coding from incandescent to LED. I fought this for a while then bit the bullet and purchased the durametric pro tool....made the coding changes and worked like magic.
The real cost savings was not having to have the bumper painted. I lucked out with it being a factory match and minimal scratches. With the Aero bumper, you don't have to purchase the grilles, fogs and LED spars. Here's most of the cost break down:
$288 Turbo front bumper (ebay)
$0 Paint (elbow grease)
$360 Grille inserts, 3 piece (ebay)
$399 LED spar (ebay)
$100 Lower lip (ebay)
$145 Fog light pair (car-part.com)
$50 Various connecters (ebay)
One day I'll take some better pics, but here's a different angle
Before
After (just buffing/polishing)
Before
Before
Before
Understood on having the rear wing functional. Add $500 for the cost of hydraulics (if I'm lucky) and another $800+ on an airbox that would allow the room, it's just not worth the cost to me.
Unless someone wants to sell me a fabspeed intake for cheap
Before
Before
misterdega (04-26-2023)
awesome!
Before
Before
The pink one is a stock TT decklid with active aero.
The silver one is a RUF full CF decklid with their fixed wing that I converted to be active aero with hydraulics from a 996 TT and then changed those to Eram electric versions to get a 1" taller, 3" lift. I used a CF bicycle handlebar as a wire channel to keep everything tidy and to match the CF.
