997.1 air box
997.1 air box
2008 997.1S 3.8L. During an air filter change I noticed the bottom of the airbox did not have a screen. The filter was exposed and very dirty. I have seen a white screen material in photos of the bottom side of the airbox. Is this an issue to be fixed?
https://www.sonnenporscheoemparts.co...ir-intake-scat
I don't think it screens much - your filter element does the heavy lifting.
IIRC it sits in the bottom of the assembly and it's called a strainer frame - the strainer being the material that seems to be missing from OP's box...and it's much smaller than the air filter element. The air filter element sits in the box and is supported by the edges of the box itself.
Looks like this. The purpose is to keep debris out but let water drain through it.
I see it now. Does look promising.
https://www.suncoastparts.com/produc...=997236mainair
To my knowledge no post-997 airbox contains a screen on the bottom-- if they do at all they're located on the walls (linked example) or above the filters (below).
GT3 Touring
Makes no sense that they'd add the screen for sound boost AND a Helmholtz resonator though.
That screen can be replaced. I replaced mine myself since it was torn.
I bought from sunsetporsche parts.
997-110-240-00 Lower Frame $30.40 1 $30.40
here is my old and new one.
