Does anyone have an easy solution to make this a switched outlet? I keep leaving my phone charger plugged in on accident. I'm sure a lot of you have experienced the same thing.
Should be really easy, if you're okay with hacking the wiring a little bit...
You can either run switched power from the fuse box and replace the hot wire with the switched one. Or, you can install a relay, if there's any type of switched wire already behind the radio.
Assuming the load is only for a car charger, I'd probably just run a new 12v wire. It would only take 5 minutes. I think fuse C6 is used by most.
Rewire it to an empty, switched fuse. You will run a fresh wire. For the fuse, you can buy from any autoparts store, a fuse with an extended pin where you can attach the hot line (then on to the center pin of the socket).
Will have to pull your fuse cover, and look for empty slots, then cross reference them..... you may then be able to assume if they are switched or not.... plug in the fuse, put the ground wire to an available ground, and the just test it. If there are no available slots (I am sure you will find a few), you can choose a low-priorty fuse, pull it, and replace it with one of the same value that has those access pins.
All of this can be done for a few bucks and some ibuprofen. This is easy work.
Peace
Bruce in Philly
This one preserves the existing circuit, hence fuse #1, and then applies power to fuse #2 for the device you want to power.
Peace
Bruce in Philly
Thank's Bruce, I will report back. You have been a great help to the forum, I have read so of your other posts.
i did this earlier this year, tap into the fuse box for an empty switched fuse, with the other end being a cigarette lighter.
from wire it so that it hides underneath the steering wheel/pcm area and plug in your new cigarette lighter an apple certified (or good quality 1.0/2.4A usb plug). from there i just use a certified power cable and wrote it beside the air vent via the gap in the side leather piece of the pcm.
as things change over time and phone requirements change, just simply swap out a newer generation cigarette lighter (and cable).
Peace
Bruce in Philly
