Replacing rear tires / do fronts as well??
Hello,
Last replaced all 4 tires 21000 miles ago. The rears are done the fronts still have a little life. Wondering who would replace all four out of convenience, fronts are only $100 a pop.
Any thoughts?
Any thoughts?
Received 5,388 Likes
How old?
Match the fronts with new rears. You don't need all four new. Unless they are 5 years old.
$100 front tires? That's super cheap.
Originally Posted by LexVan
How old?
Sumitomo tires are actually pretty good and amazing value. Have had them in the past and no complaints. Now as others said, since price is quite good, do all four.
If staying with the same make and model of tire as what's on the front, there's no need to prematurely change the fronts until they're worn out. Most 997s will go through 2 sets of rears for each set of fronts, sometimes even 3 sets of rears for 1 set of fronts if doing a lot of hard accelerating.
Even though it's only $200, if you want to throw away money, I can send you my PayPal address
If you change just the rears now and then the fronts when they come due, there is the incremental cost of another tire shop visit, beyond just the cost of the tires themselves.
If that added scheduling/going there is worth less than the cost of the remaining life on the tires (which isn't much if they are 5 years tires that cost $100, and are not quite but a good way used up), then sure, change them.
When I was in college, and had lots of free time, sure I'd have no issue doing just what needed doing. Now in a full adult life with lots of scheduling responsibilities, I'd pay money to combine shop visits.
