Durametric Pro Rental - Now What
I was getting tired of the 74mph beep because of my fixed wing so I rented a Durametic pro. So the wing is fixed but I have this thing for 10 days. Now what do I do with it?
So far I have disabled the rear wing, disabled the TPMS, reset my service light, ran an over rev report.. I have nothing in 3, 4, 5 or 6 (yeah!!!) And only 8 hits in 2.
Is there anything else I can do with this overpriced cable..![Confused](https://rennlist.com/forums/images/smilies/confused.gif)
---EDIT : Below Line Codes Changed and working on 997.2 C2 ---
Over Rev Report
Engine / Information
Disable Rear Wing
Rear / Coding / Spoiler Function / <Not Active>
Seat Belt Chime
Airbag / Coding / Belt Buckle, Drivers Side / <No>
Airbag / Coding / Belt Buckle, Passenger Side / <No>
Side Marker Turn Signal
Front / Coding / Side Marker-Direction Indicator Light / <Direction Indicator>
Windows up on Lock and down on Unlock
Alarm / Coding / Comfort Radio Remote / <Active>
Alarm / Coding / Comfort Function Window / <Active>
Left Door / Coding / Comfort Closing / <Off>
Left Door / Coding / Comfort Opening / <Off>
Right Door / Coding / Comfort Closing / <Off>
Right Door / Coding / Comfort Opening / <Off>
Over Rev Report
Disable Rear Wing
Seat Belt Chime
That darn seat belt chime​... Good ones.. thanks
Looks like you can change the shift up arrow. Hoping you can just turn it off. That thing is worthless.
The most important thing about a Durametric is for diagnostics. But if you want to "code", there are big differences between the capabilities of 997.1 vs 997.2.... the ability to code was greatly reduced with the 997.2.
Try here for a manual: https://rennlist.com/forums/997-foru...-manual-2.html
The most valuable for me was comfort option .... holding the unlock button on my key and dropping the windows.... great for getting heat out of the car as you are walking towards it.
Peace
Bruce in Philly
Peace
Bruce in Philly
Thanks Bruce... figured that one out last night. Agree... nice mod.
Added to the first post what I have done so far. A lot of info out there but not in one place and not for the 997.2
