2013 boxster hood closed with no connections to the battery
Do the new models not have the contactor pull out in the fuse panel? If they do, you slide that out, supply 12v on the slide-out and then use the release button on your key remote to pop it, not the release switch in the car.
Your owner's manual also probably has information on what you need to do for your specific year and model.
Mods, I didn't start this thread, just responded. OP must have deleted the original post. You can close or delete it since I guess he found his answer reading the manual.
