Fabspeed Headers
I have not added the headers but thought I'd chime in about the great quality and improvements I have experienced with Fabspeed. My 1st mod was the Fab Dual Air Intake, then the 200 cel cat bypass pipes were installed. ECU tune thru their shop finished it for this year. Worth every penny and the fit and finish are superb. I will probably have the GT3 throttle body done next and retune. I should do the headers, but it is plenty loud for my neighborhood as is.
I have a complete Fabspeed setup on my 997.1 - J-pipe intake, equal length long tube headers, valvetronic mufflers, 200 cell X-cats. Excellent quality, fit, and finish and no issues at all over the 4 years they've been installed.
The headers wont increase the sound much if at all, just improve the flow by properly sequencing the exhaust pulses and eliminating the turbulence within the stock header design.
I would recommend OEM X51 (same as GT3) headers. Factory quality and proven performance
For muffler, it's more about sound than power (regardless of the claims of manufacturers, or fan boy owners who never did a before/after dyno but are certain of power increases). I like Tubi and Akrapovic, but it's a subjective call.
See this thread where I posted a lot of info on headers with pics - https://rennlist.com/forums/997-foru...l#post14461623
Neither the stock OEM or X51 header design is as good as the Fabspeed one. For optimal flow, the length of the pipes from all the cylinders on one side of the motor need to be the same and the gasses should flow in the sane direction where they merge into the collector, not come in from different angles, which creates turbulence and inefficiency.
I just replaced my997.2 X51 headers and cat with the Fabspeed headers and 200 cell cat. Earlier this year I replaced the third muffler with Fabspeed X pipe. On each upgrade there was a little bit of increase, performance wise, but the sound is sooooo much better. Car finally sounds like it has some *****!
Basic Sponsor
I have a complete Fabspeed setup on my 997.1 - J-pipe intake, equal length long tube headers, valvetronic mufflers, 200 cell X-cats. No issues, excellent quality, fit, and finish and no issues at all over the 4 years they've been installed.
Check out the 997 S and X51 headers side by side:
Our design incorporates a proper merge collector and eliminates turbulence and inefficiency by incorporating a longer tube design than stock, a more equal tube length than stock, and a velocity spike inside the merge collector to help smooth out the flow:
Porsche is very calculating in their model lineup. I suspect to get the S to fall where they wanted between the base and x51 they restricted the S exhaust and saved some money to boot. That S header is ugly.
Basic Sponsor
They're both ugly honestly! even the X51 design does not have a proper merge collector. As you mention Porsche is very precise in its lineup and model ranking! Restricting exhaust systems/components is only one way they accomplish this.
yeah I would think, even without dyno testing that fabspeed (or just about anyones) headers would be better than stock, even stock x51. I have an x51 engine and I'll be upgrading the headers and cats as well.
