Sonax Wheel Cleaner
Sonax Wheel Cleaner
I had read on this forum about how good Sonax wheel cleaner is. I ordered
a bottle from Amazon. Today, used it on my wheels for the first time and was amazed at the results. I let it set for five minutes and then hose it off. Wheels were 90 clean and only required a little touch up. I highly recommend this product. (I have no affiliation with this company.)
I always used Sonax till I tried this DUB stuff in link below. It is at Walmart and it is the exact same stuff.
https://www.walmart.com/ip/DUB-Devel...eaner/33080657
it is NOT the exact same stuff. Use your words.
Sonax works great. Used for years. Also have used Adams Wheel Cleaner, 1Z Einszett which is now known as Nextzett, and many others. P21S is also a great option on wheels where you are more concerned with the finish, like older wheels.
Sonax is very good. There are many brake cleaning products nowadays that have the same "iron removal" capabilities and color change as Sonax, so select away. Are they identical -- no, but there are many that are so close (performance, safe for all wheel finishes, etc.) that price and availability might be the only important factors.
Me personally, I coated my wheels with Opti-Gloss so I never need anything besides water and carwash soap or rinseless wash to get my wheels sparkling. However, I do keep Sonax on hand for just in case scenarios.
PS: what in the world is "Pina Caliente" scent - LOL (from the DUB description)
Former Vendor
NOT the same stuff. This DUB branded cleaner doesn't state it's specifically PH Neutral which is one of the most important parts for a wheel cleaner. These wheel cleaners you can find at Autozone have acidic compounds which over time will cause your wheels to look like they're faded, but PH Neutral cleaners like the SONAX product cause no harm to the wheel finish.
DUB MSDS http://www.meguiars.com/content/es/msds/U14%20SDS.pdf
Sonax MSDS http://www.servicebest.com/downloadable/1837512_EN.pdf
Just because it is sold in Autozone doesn't mean it is acidic or caustic, although many wheel cleaners are! So be an informed consumer especially if you have polished aluminum wheels or another sensitive finish.
Former Vendor
While I've never used the DUB cleaner (like I mentioned, I use Sonax in the rare occasion I need a wheel cleaner), it is essentially pH neutral...7.36. Sonax is "7-8.5"
Always better safe than sorry! Manufacturers are not very transparent on the chemicals they put in these cleaners, so have to seek it out at times.
But I tell you what, if I had a $5000+ set of wheels, you better believe I wouldn't cheap out on wheel cleaner. Sonax is good stuff. I am glad HRE educates their customers on proper wheel care. Best recommendation is to have the wheels coated (SiO2, "ceramic",etc. plenty of products out there) and they will always be easier to maintain.
Former Vendor
I have a bottle of Kamikaze Stance Rim Coat at home that I haven't used yet, but I've seen that stuff in action, and there's no doubt in my mind for any future wheel set I get, I'm putting that coating on. Makes life so much easier to maintain as you say, and that's a blessing especially considering wheel designs are getting more and more complex these days.
Someone said that Sonax and other iron removers do stain painted calipers over time...
Sounds like "fake news" to me!
Seriously, you can use it on your car paint with no damage - it will not damage painted calipers. I could see the potential for "staining" if used on very hot calipers and letting it dry, but that could happen with a myriad of chemicals.
Love everything about sonax except the price! Always seems to go quick. Never had any staining problems with it personally, just spray on right before I get everything ready for cleaning, then wash it off when I do my rinse.
I did luck onto a gallon of it for $43 from Amazon shipped. Was a great deal. Should be good for a couple years between the two cars.
Sonax is the best and all I use.
