I'm new to the community for the most part and thinking I might be pulling the trigger on a 997.2 C2S w/ sport chrono plus. It's got 40ish K miles, and not CPO'd. Coming in at $51k, which seems pretty competitive. Lmk otherwise guys
Here's what I'm doing to check it out, but would like to get all your opinions on what else I should be looking at before I sign:
-Will be PPI'ed it at a Porsche dealership
-CarFax is clean 1 owner car essentially
-Options out at over $105k, so asking seems in range for market and options
From my research, 997.2 apparently don't have the IMS / RMS issue at all, so it's solid in that respect. However, are there other things I should be asking during the PPI specifically to catch hidden issues?
Thanks everybody in advance for your opinions and guidance to a noob P-car guy!
Check everything. PPI should tell most things but this is a 6+ year old car with 40k miles.Who knows what the last owners did?
In general these are great cars and welcome to the club.
I knew less than you do when I bought mine 2 years ago.
Costly potential wear items are brakes (rotors and pads), tires, 40K service (belt, spark plugs, air filters, oil and filter, brake system flush) possibly water pump and coolant reservoir. PPI should look at that and more, does the AC blow cold? PDK serviced? How is the clutch? The 40K service at a dealer is 1500 or so, Indy is less, or you can do yourself with tools and bloody fingers.
DC911S is spot on. The biggest issue you may face is deferred maintenance and the cost of having these services done if you don't know how to do them yourself.
So far, there are relatively few problem areas with the .2s. If you're going to the expense of a PPI, you could go hog wild and get the cylinders scoped to make sure there is no bore scoring, but even that seems to be a very rare occurrence.
Going on memory, the problem areas with the .2s seem to be (in rough order of importance and cost):
Bore scoring (very rare)
Water pump failure
Air Oil Separator failure
High pressure fuel pump failure (usually occurs with the first owner and was fixed under warranty)
Unexplainable electrical gremlins (more often than not can be fixed by replacing the battery)
Water pump failure
Did I miss any, guys?
Not necessarily a problem area but the PDK can be a replacement-only item at high cost so making sure there are no issues with it is very important.
Thanks! Good thing is I was able to talk to the previous owner, seemed to be on the up and up, he had moved onto a 991 Turbo, and did say the 997.2 was never problematic and he serviced it regularly at the same dealership which records show he did.
Water pump failure
This is the stuff I knew you guys would be great in giving advice. I'm going to make sure to look at these in the PPI report. 6MT, so no pdk.
Question Id have is whether any of these issues above are castastrophic if not caught in time. Ill have to look up bore scoring.
This is great advice.
One additional item I would add is to ask the dealer to pull the oil filter, cut it open and inspect for debris. On a .2 you shouldn't lose any oil. It will cost you an extra $30 for the filter, or $150 if they require a full oil change. Based on personal experience I would spend a few extra bucks for piece of mind.
Thanks guys, moving onto a newer 2011 potentially and will be making sure to take a look at everything. It's CPO'd though this time, so I'm thinking it's relatively all in order.
