Eibach vs H and R, mistake?
Supposed to be dropping my car off to get lowered this weekend. I bought eibachs and now wondering if it's going to be low enough for my liking... I obsessively read every post about lowering springs and realize that most went with eibach , now wondering if i made a mistake ? maybe I should have went with H and R, seems like that drop is noticeably different...I just don't want to do eibach and be dissapointed that it's barely noticeable, should I plow forward or return for H and R? I would rather sacrifice a bit of ride height than ride quality if that helps, thanks for your input.
PS it's a 997.2 c4s with PASM
1 Post
I just went with H&R as well and it put a smile on my face.... I will say that it is low for just being springs. I don't daily drive the car and it does take some navigating through speed bumps/humps and steep entryways/exits, but I could easily daily drive it if need be.
Can't go wrong with either.. if you have had other cars low, go h&r. If this is your first rodeo, go eibach.
With any car, Eibach is always the more conservative route.
The look is subjective but both are significantly better than OEM.
The H&R's drop another 1/4 to 1/2" compared to the Eibachs depending on who you listen to
I have H&R and it is the perfect drop. I would definitely go with H&R.
