Replacement Space Saver Spare Tire
#46
As I stated earlier this has been discussed. My first recollection of this discussion was in the early 2000's. See post 10 of the attachment where a Porsche TSB was quoted. Although for a 1998 Boxster, I'm sure everyone is familiar with the cost savings advantages when Porsche used the same/similar front clip design for the 996. I'm going to go with the theory that structural discussions of the boxster front end 'might' be applicable to the 996. Maybe future generations deviated' I don't know. Following the TSB may not be necessary but may be prudent.
https://rennlist.com/forums/996-foru...tire-bolt.html
Or
http://www.renn-list.com/Keep-the-sp..._10445530.html
#47
IMO I would be careful in assuming if the owners manual is silent on a subject, it's safe to do. It may simply be a case where it's silent on the subject (e.g. No mention of structural steel supports in the door either).
Or
Or
The 996 Turbo has a different front end.
If one is that concerned he could visit his dealer service department and ask if there is some TSB related to the Turbo spare tire being removed. I suspect there is no such TSB.
Also, last but not least there is this from the TSB:
"In addition to its intended purpose, the spare wheel fitted in the luggage compartment also serves to absorb some of the impact energy introduced into the front of the vehicle in serious frontal collisions. Please take this into consideration and drive with the appropriate care when, in exceptional cases, the spare wheel is not carried in the luggage compartment."
The OP is seeking to remove the spare on special occasions so he should just drive with the appropriate care when, "in exceptional cases", the spare is removed to make more cargo room.
#48
That TSB applies to the early Boxsters and because of the similarity to the 996 the early 996.
My main point is not to assume silence on the part of the owners manual is tacit approval to make changes. Again simply one opinion; feel free to draw your own conclusions. I'm never one to have to prove myself right. I feel better saying IDK.
#49
Understood. I'll let those that truly want to find the appropriate TSB visit the dealer. I'm satisfied to leave mine in.
That having been said, I'm somewhat surprised at the reverence given in these forums to the owner's manual. I have always assumed that these things were hastily thrown together right before the launch of the vehicle, assuming that maybe someone would consult them to figure out how to use the windshield wiper blades, but perhaps I am mistaken. It is very common for resale vehicles to not even have the manuals remaining in them, and Porsche, unlike BMW, does not even go to the effort to make their users' manuals available online.
What am I missing here? What is so special about Porsche owners' manuals that they deserve to be treated as some sort of holy grail about how the vehicle is to be operated?
#50
It is not an engineering design manual. You would need three thick volumes. That's why if you have more detailed technical questions, reference the Service Bulletins or the separately produced factory service manuals. But even those can't contain everything and they are expensive. Engineers just don't put everything they know on paper.
#51
so.. my car with 9"'s in front,.. i always felt plowed a bit, so i removed the tire thinking just *maybe* a lighter front would benefit my slow speed but anarchic cornering
First off, I have no knowledge whatsoever about crash testing of the 996TT or the potential function of the limited service spare in crash protection, which is located below the "Frunk."
but then, it's ( the manual ) not something to be trifled with either. plus, it has all the day to day stuff one needs when maintaining the car, changing bulbs or operating the set memory positions LOL
needless to say, i lost my owners manual years ago
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
#54
As I mentioned in another thread, I took my 996TT into the Porsche dealer today to get a couple of spare keys, being as the car was sold with only 1, very old, key.
I ended up having a conversation with the manager of the service dept., who also brought in the head tech part way through the conversation. I asked if there were safety considerations to removing the spare tire in the 996TT, if it was part of the crash safety design.
The head tech said he would leave it in there, that in addition to the Boxster previously mentioned, he thought that there were some service bulletins about leaving this in the car for other models. He said that if it was his car, he would not remove the tire just to get the extra storage space.
#55
For perfect balance, remove the spare and add exactly 8.5 kilos (dry) of quick-set concrete poured directly into the very bottom of the frunk well. Lightly saturate with sparkling water (weights less), preferably Perrier. Completely eliminates the bounce and improves crash safety, all for about $6 (though more like $66 if you use the Perrier, but it is a Porsche after all).
#56
I asked my tech and he actually said that San Pellegrino works better. To each his own, though.
#57
Concrete is very heavy, and I think you will find that only an inch or two of thickness will exceed the weight of the spare tire. As a result, in a frontal collision, whatever was collided with will tend to go right over the concrete, and easily enter the passenger compartment, probably right at the level of your ***** (if present).
Hope this helps.
#59
Thats why you need the quickset concrete and sparkling water.... Really low compressive strength so it crushes/crumbles upon impact. Afterwords, just stretch the damage out on a frame rack, vacuum out the concrete dust, and pour in a new layer.
