996 Turbo Forum 1999-2005
Ultimate Motorwerks Rear Wing Lift Cylinder Repair Kit
Old 04-22-2021, 12:16 PM
  #121
Bernard IV
Bernard IV's Avatar
Looks really good. Not cheap I imagine.
Old 04-24-2021, 08:25 PM
  #122
Kevin
Kevin's Avatar
Spent some time building the taller 997TT CAB wing cylinder cartridges.
The following 3 users liked this post by Kevin:
Dock (04-24-2021), lowmiler (04-25-2021), vongo (04-24-2021)
Old 04-25-2021, 02:17 PM
  #123
napoleon1981
napoleon1981's Avatar
When prices are kept secretive thats usually not a good sign.
Old 04-25-2021, 02:51 PM
  #124
Bernard IV
Bernard IV's Avatar
Yah super secret pricing. He's got a lot of time into a bit of a lower volume selling part so I'm not blaming anyone. It costs what it costs. I know the Pspeed guys are at around $800.
Old 04-25-2021, 04:10 PM
  #125
Brainz
Brainz's Avatar
Nice work, Kevin. Those look terrific. Your stainless cylinders are beautiful and are likely to outlast the car.
In 2018, I managed to make a pair of serviceable cylinders from scratch for my 997 using a small hobby lathe -- I don't remember now how much time I spent, but it was a lot. I didn't have the tools to ream a smooth cylinder bore, so I bought brass tubing that matched the factory dimension and silver soldered machined fittings onto the tubing that allows for servicing the o-rings. I also didn't want to do internal threading, so I ended up using 3 cross-drilled set screws that recess into a relief groove on a removable part.
Here's a picture of my work. I'm not advertising or selling -- this was done all for the learning/challenge -- it's not my business. I'm happy to offer thoughts to others on what I did, but this is really not DIY stuff unless you've got access to a lathe and know how to use it. Sorry, no pictures of individual pieces, and I'm not about to take it all apart again...
Dingo (04-25-2021)
Old 04-25-2021, 04:24 PM
  #126
Kevin
Kevin's Avatar
Pricing depends on what each individual has for damaged or missing components. From a single hydraulic cylinder ram assy to a full rebuild of the hydraulic pump, hydraulic lines and two hydraulic cylinder ram assy.
Recent examples have new 996TT owners finding out that there new 996TT have fixed rear wings. Only to find out that they don't have a hydraulic pump, and/or hydraulic lines. This also includes finding missing or cut electrical harness and failed limit switches.
However, I will say that Retail pricing for a rebuilt 996TT wing cylinder RAM assy is $795.00 This price requires the owner to send me his wing cylinder RAM assy in for rebuild.
On top of that, Car dealers, and Porsche dealers want complete working hydraulic wing assemblies. Plug and play Exchanged.
My new 996TT and 997TT hydraulic wing cylinders RAM assemblies are unique. We now have a "New" redesigned cartridge that will allow VITON oring replacement.
I can now "hone" the bore to clean up any scoring from alkaline buildup (from high detergent car washing). I even have oversized piston packs if I have to oversize the bore.
Ultimate Motorwerks 996TT and 997TT wing cylinder RAM assemblies are available for owners and Automotive sales and repair centers that want to keep the factory system.
Old 04-25-2021, 05:01 PM
  #127
Bernard IV
Bernard IV's Avatar
Any possibility I could just buy 2 ram cylinders and have them sent to my place?
Old 04-25-2021, 07:27 PM
  #128
jpflip
jpflip's Avatar
I like that ;-)
Old 06-13-2022, 01:06 PM
  #129
Jeff777
Jeff777's Avatar
I have a driver side spoiler that doesn't extend all the way either automatically or manually. It will retract both ways but only extends about an inch while the passenger side extends full length. There is no apparent leak and no noise. The durametric doesn't show any fault codes. Would this be indicative of a microswitch or hydraulic issue?
Driving a 2001 996 turbo.
Cheers
Jeff
Old 06-13-2022, 01:52 PM
  #130
RennKit-Dave
Basic Sponsor
RennKit-Dave's Avatar
Originally Posted by Jeff777
I have a driver side spoiler that doesn't extend all the way either automatically or manually. It will retract both ways but only extends about an inch while the passenger side extends full length. Would this be indicative of a microswitch or hydraulic issue?
Cheers
Jeff
Probably low on Pentosin PS fluid. That side has no microswitches (unlike the Carrera GT) so the computer doesn't know it is malfunctioning. There are methods to top off the hydraulics and bleed, including one guy that recommends removing the back lid altogether.
Dave
Rennkit
djcooper@rennkit.com
http://rennkit.com/
  • Patented eRam Kit™ for 996/997 Turbo & Carrera GT wings
  • Cal*Cool™ - brake cooling 996/997 / Bluetooth Retrofit Kit™ for 1998-2011 cars / Wing Extenders™ 987 Cayman / 997 Turbo
  • AUTO-BLiP for MT / Function F1RST Shift ***** / Girodisc 2-piece rotors / OS Giken LSD / Phenix suspension / Zunsport grills / 997/987 switches/PCM ***** / Border Coilovers
Old 06-13-2022, 04:13 PM
  #131
Kevin
Kevin's Avatar
I would disconnect your two wiring connectors at the electric pump motor. This is done to prevent the drive block damage internally.
When you have time, you can empty, fill and bleed the wing hydraulic assy. Use Pentosin and 30% by volume Lucus Power Steering stop leak. (Don't use more than that)
For minor leaks this will cure flat spotted orings. I have new wing cylinder ram assy available..
Old 06-22-2022, 08:30 PM
  #132
Jeff777
Jeff777's Avatar
Thanks guys. It seems to have worked. Definitely could use a helper but all good so far!
Old 06-24-2022, 09:51 PM
  #133
Jeff777
Jeff777's Avatar
Maybe a bit premature to celebrate. When I put the cover over the micro switches it seemed to trigger the warning. So I left off the cover off (is this a good idea due engine heat?) and the warning stayed off. Went for a short drive and the spoiler worked up and down both manually and automatically. A few seconds after first spoiler deployment the warning came on but the spoiler still operated. Both micro switches seemed to be still seated after the drive although the rear switch seemed the least solid. Any ideas? Is this a microswitch issue to be replaced?
Old 06-24-2022, 09:59 PM
  #134
RennKit-Dave
Basic Sponsor
You certainly need new microswitches.
Old 06-24-2022, 11:58 PM
  #135
Kevin
Kevin's Avatar
If you have not bled the system good enough, you can have issues. The upper microswitch might not trip or hangs. The chrome plated cylinder has notches that trip the "sail switch" Upper and lower...
Make sure that your cylinders are reaching the max height and do not sag.
Did you remove the microswitches during the drain, refill and bleed process? How many times did you cycle the pump? Did you measure the extension "max height"
Rarely do I see microswitches fail, usually they suffer handling or collision damage. If you bend the sail switch>> you will have problems.
Quick Reply: Ultimate Motorwerks Rear Wing Lift Cylinder Repair Kit
