996 Turbo Forum 1999-2005
Clutch and steering problem
Old 10-08-2016, 11:23 AM
Freddie Two Bs
Freddie Two Bs's Avatar
Default Clutch and steering problem
So today all of a sudden the clutch pedal is hard as a brick, and the steering wheel is hard as ****, too, and will only turn a few degrees.
I guess that's because somehow the pentosin leaked out? Where does it normally leak from? I have a fresh power steer reservoir and a fresh slave cylinder.
Old 10-08-2016, 12:03 PM
911mhawk
911mhawk's Avatar
Check the resivoir under the bonnet to see if it has leaked out of there.
If so, time for a new slave & accumulator.
The PS resivoir is easy to check on the engine, small black cap on silver power steering resivoir below the oild fill.
Old 10-08-2016, 12:16 PM
napoleon1981
napoleon1981's Avatar
I think this is a slave issue. It sounds like a general powering steering issue, since the whole circuit appears to be unassisted. Start with checking fluid levels. If low see if you can find the leak, I would start by looking at recently replaced parts and their connections. If fluid levels are good, it sounds like a bad pump.
edit: I assume your observations are with a running engine correct?
Old 10-08-2016, 12:27 PM
Freddie Two Bs
Yes running engine... Thanks
Old 10-08-2016, 03:38 PM
Freddie Two Bs
Front reservoir area is dry. Rear reservoir is empty. I'll fill up with a bottle of CHF11s and see if I can spot the leak. Going to the mechanic on monday anyway.
Old 10-08-2016, 06:02 PM
32krazy!
32krazy!'s Avatar
no need to spot the leak. slave and accumulator are gone 1 can of petosin is 28$ no need to waste it
Old 10-08-2016, 06:38 PM
Freddie Two Bs
Any logical reason why a slave cylinder installed 2k miles / 7 months ago has already failed?
Old 10-08-2016, 08:26 PM
Freddie Two Bs
Update: there's a massive leak coming from just in front of the rear axle. Filled it with pentosin and went almost straight through. This puddle formed in a couple minutes.
Would this still have to do with slave and accumulator?
Old 10-08-2016, 08:34 PM
napoleon1981
Yes that where they sit, driver side, right in front of the rear axle (in the picture left far into the garage of the puddle is where it likely starts). It really looks like some connection is loose given the pace this stuff runs out. How old is your slave? Did you have an accumulator replaced? I have heard about those coming loose too.
Just a warning pentosin is pretty corrosive. It eats hoses, including the waters hoses and axle hoses that are in the area. If you could clean it, it may save you money down the line.
Old 10-08-2016, 08:46 PM
Freddie Two Bs
Slave was replaced just a few months and a few thousand miles ago.
Am I gonna **** up the steering if I drive it four or five miles to the mechanic in this condition?
Old 10-08-2016, 08:53 PM
Carlo_Carrera
Carlo_Carrera's Avatar
Received 2,497 Likes on 1,576 Posts
If you do drive it clean off the leaking Pentosin really well. It is highly flammable.
Old 10-08-2016, 09:03 PM
Kevin
Kevin's Avatar
With the puddle under the car, and no Pentosin in the front slave reservior, you most likely have a empty power steering pump. You are heating up the power steering pump and risking accelerated wear.
You have a pretty good breach at the slave, slave acculator oring, or connection lines..
I'd call AAA or a towing service for this one. If you have a blown pressure side line or connection> Pentosin is very flammable when sprayed on cats or hot turbine housings.
Old 10-08-2016, 09:13 PM
napoleon1981
My bet is that your slave is fine. I think its something in the connection circuit.
I would not drive the car. A tow is relatively cheap compared to damaging a power steering pump. Also, you can see that your car is quite wet all over. Given the already pointed out flammability of pentosin, I would not risk it. Have the car cleaned well too.
Old 10-08-2016, 10:07 PM
911mhawk
911mhawk's Avatar
I had an accumulator come loose that puked out a bunch of Pentosin too.
Thought I had blown a line but ended up just needing to tighten the accumulator and re-bleed.
Old 10-08-2016, 10:54 PM
"02996ttx50
"02996ttx50's Avatar
I'm betting on a half assed install of your ps res and or the slave. one would imagine that you'd hear the whine of an empty ps reservoir since its immistakable, upon any turning of the wheel. ( oh wait, wheel wont turn! that'll do! )
bottom line is you have massive leak and no fluid in the system. tow the car.
Quick Reply: Clutch and steering problem
