996 Turbo Forum 1999-2005
Coupe vs Convertible
Old 09-18-2016, 12:38 PM
  #31
wross996tt
wross996tt's Avatar
so which is it...coupe or cab?
Old 09-18-2016, 02:18 PM
  #32
Q's911
Q's911's Avatar
Coupe
Old 09-18-2016, 02:21 PM
  #33
Q's911
Q's911's Avatar
Originally Posted by Therapy996t
Hey, good luck on the purchase. I literally just bought a 996 turbo about 2 weeks ago. Mine is a Coupe and I am awaiting delivery for it (couldn't get away from work to go bring it home myself). As for the convertible vs. coupe business, if you don't mind the look of the rag top, get it. Absolutely get it. Having owned convertibles in Alaska, Eastern Washington State, and Michigan, I can tell you that when you put the heater on in cold weather, which you would do anyway, you don't notice a difference. You would probably get a little more wind/road noise, but I thought it was dailyable Just my two cents. Also, my dad had an old Saab 900 turbo with a rag top, also in Alaska, and he didn't have a problem with it at all. Though his car had heated seats Let us know how the hunt goes!
Cheers,
What company did you choose for the delivery service? I did a search and found that Innercity is one of the best but I'm awaiting a quote… Kind of on a budget so like to find something affordable.
Old 09-18-2016, 02:46 PM
  #34
Freddie Two Bs
Freddie Two Bs's Avatar
I had my 74 delivered by Intercity and I was quite happy. Certainly not the cheapest, but moving good cars is all they do and they operate their own trucks. A bunch of companies will charge you less but will only act as brokers, handing out the job to one of many subcontractors. If I were you I'd make an effort to go either with a local guy who can be trusted in the extreme (like recommended personally by someone with credibility and a reputation to maintain) or one of the large companies (intercity, reliable, etc.).
Be prepared to wait several weeks before you get your car. Scheduling a pickup again can take two or three weeks easily.
Old 09-18-2016, 03:27 PM
  #35
Therapy996t
Therapy996t's Avatar
Q's911: I don't really know, yet. Porsche of Tysons Corner does what Rick Brooklyn said most do. The dealership is going to put out a bid (whenever the clutch work is done) and whoever picks up the bid gets to move the rig. That said, I don't see how being picky will make much of a difference. All the truckers carry insurance and if something does go wrong (accident, scrape, hail, bad loading ...etc) insurance picks up the tab. The only thing that would make a difference, that I can see, is whether you get covered trailer or an uncovered trailer. For me, I am OK with an uncovered trailer because it's 100K mile paint and I'm a little less picky; but for you and your garage queen paint, I might spring for a covered/enclosed trailer. Covered trailers cost a little more, but in your case it may be worth it.
Cheers,
Old 09-18-2016, 06:08 PM
  #36
leftlane
leftlane's Avatar
Fly out and drive it home. Cheapest way to do it and will be a memory forever.
Old 09-18-2016, 08:46 PM
  #37
kmagnuss
kmagnuss's Avatar
Good luck having a truck shipping company pick up any insurance tab. Lol... I ship heavy equipment 5-10x a week with most being between 100-200k and you may as well try to pull some hens teeth if you think you're going to get the trucker's insurance to pay for anything... and if you do get them to pay it won't be the full amount and it will take a LOOOONNNNGGG time to get the check.
Don't hire a broker (like we do)... hire a reputable company and have it done right. It's worth the couple hundred extra. If you're balking at that couple hundred extra you're buying the wrong car and setting yourself up for a disaster of an ownership experience.
Old 09-18-2016, 08:47 PM
  #38
kmagnuss
kmagnuss's Avatar
This.
Old 09-18-2016, 10:01 PM
  #39
Q's911
Q's911's Avatar
I'm thinking about it...road trip anyone
Old 09-18-2016, 10:21 PM
  #40
Q's911
Q's911's Avatar
Here are some pics..excuse the quality, will post better pics she arrives!
Old 09-18-2016, 10:49 PM
  #41
Q's911
Q's911's Avatar
Below are some numbers from the PPI. The mechanic was impressed with the overall condition of the car. What do you guys think...
Old 09-18-2016, 11:17 PM
  #42
Q's911
Q's911's Avatar
As i have no idea what the hell those numbers mean!
Old 09-19-2016, 12:49 AM
  #43
911mhawk
911mhawk's Avatar
It's a little before 7 and your battery is more than half full.
Old 09-19-2016, 03:09 PM
  #44
996SPECticle
996SPECticle's Avatar
Layman speak
They are 2 engine health metrics that in general test the same parts of the engine in different ways.
Leakdown is an amount of pressurized air through the spark plug hole that gets past the valves and rings in a period of time while the valves are closed, engine static. I don't believe any are perfect so I assume the 5% is good. Higher %#s would indicated burnt valves, worn rings/cylinders, etc.
Compression is in lbs psi generated by the pistons and measured at the spark plug hole while the engine is being cranked over. The numbers vary depending on the engine, there should be a baseline to compare it to. What you are looking for is the difference between cylinders and can be acceptable up to ~10% difference. Your numbers look wonderful AFAIK.
Old 09-19-2016, 09:13 PM
  #45
wellcraft290
wellcraft290's Avatar
When I bought mine. Cabs were more money then coupes and love my cab. Also because you usually can't track a cab easier to know wasn't tracked.
Quick Reply: Coupe vs Convertible
