Rear spoiler goes up and down fine but an error light comes on
I'm assuming there is a sensor that detects if the spoiler moves and that sensor has failed as the spoiler goes up and down just fine (both with the button and automatically while driving).
Does anyone know how to diagnose if the sensor has failed or if it is just a blown fuse or loose wire? If the sensor has indeed died, it is something I can easily replace myself?
Thanks!
Kevin
Thanks!
Kevin
Take a look at the right hand actuator. There is a small plastic cover over the base of the actuator. Take it off and look at the condition of the switch and also look if it is not out of the holder.....May be you got one actuator leaking....I you search this forum you will get lots of answers....
Look at the bottom of the spoiler Rams, do you see any fluid on them when you open the hood. My spoiler light came on and spoiler operated normally for months, then I began having uneven deployment. May be time to refill it.
Either way the spoiler is going to fail.
Good place for switches :http://www.digikey.ca
The difference between right & left ram operation can set off the light. Mine came on with the slightest weeping of the driver's side ram; with no perceptible difference in right/left rate of rise. It will only get worse.
Many threads here on your alternatives...
Close... Only the passenger side ram can directly cause the dreaded Spoiler Failure Warning. The drivers side has no feedback to tell the ECU if it is coordinated with the right ram. So...regardless of what the left side is doing, if the right side is not perfect (won't go up all the way, won't go down all the way, bad top microswitch, bad bottom microswitch or wiring issue...etc.) ECU throws the warning.
My driver's side ram was failing (the most common one to fail) triggering the fail light.
Dan
^ all perfectly correct advice and anyone in that stage of failure is a perfect candidate for a simple refill of fluid. problem(s) solved.
but i gotta say..dave's advice has to also though be considered as comprehensively correct as any. including dans above. he has a patent pending for cryin out loud.
i can't imagine anyone having more thorough knowledge of the inner workings of this peculiar setup than dave. criminy. either way, don't anyone dare disdain a refill. i'm on my "second" re-bleed/refill and the car is 13 years old w 135k miles and w strosek on back it works perfectly every single time. up & down ad nauseum
^ all perfectly correct advice and anyone in that stage of failure is a perfect candidate for a simple refill of fluid. problem(s) solved. but i gotta say..dave's advice has to also though be considered as comprehensively correct as any. including dans above. he has a patent pending for cryin out loud. i can't imagine anyone having more thorough knowledge of the inner workings of this peculiar setup than dave. criminy. either way, don't anyone dare disdain a refill. i'm on my "second" re-bleed/refill and the car is 13 years old w 135k miles and w strosek on back it works perfectly every single time. up & down ad nauseum
You are lucky if it's holding, based on the many stories and eRam kits out there.
it's true dave, it's fraught with peculiarities for *most* without a pretty decent level of DIY experience AND direct knowledge of the system itself.
my tech has done this a 1000 times. i kid you not. it's like an hour ( if that! ) and we listen to sublime and smoke two joints lol
