Question to the ADMIN
Registered User
This is not a big deal but before the switch over I had over 200? posts to my credit. Now I only show like 25, but some others had their post numbers carry over? Just wondering?
Thanks!
Thanks!
Hi bgainey,
Sure, I know the answer..!!! The reason is that these Forums went on line on the 14th of July, and you "registered" on the 16th of July. If you logged into these Forum with your previous screen name and password from the old Forums, your old posts would have have counted to your post count in these new Forums....
Hope this helps..!
Hope this helps..!
Registered User
Well,
I thought that I had registered with the same name? Would it still work If I was to register now? If i discover I was using a different name before?
Keeper of the Truth
Your previous user name was "BuddyG." It is still there if you want to use it again. Just login with that user name and the password associated with it.
Keeper of the Truth
When I go to register it says I am already registered? How do I change my login?
https://rennlist.com/forums/
Look for the Log Out button at the bottom right of the page. Once you click on it, you will be logged-out and you will need to re-login. To do so. Go back to the main page again (above link) and find the login windows at the top right. That's where you must enter the user name of your choice and the associated password.
Keeper of the Truth
Originally posted by BuddyG
I think I got it thanks!
