looks more like something that should be hanging on a wall
similiar to an old carb I cleaned up and mounted. Then again there is the old air plane motor i'm polishing up to hang too that came out of an old cesna! Wanna donate those to me?
Originally posted by soon2be993TT looks more like something that should be hanging on a wall
Hehe yeah Kevin did a great job Too bad they are under the car instead of visable I'm hoping for more power sans any lag
I have the same gremlins. Kevin did a very nice job. The performance has been quite good. I have run my car side by side with a turbo that ran 11.30's in the quarter and the acceleration was the same. I can also put race gas in and run about 30 horse more.
Enjoy
Ah nice one... I'm guessing one notices the difference. I'm hoping that I'll keep the little lag we have and just get that bit more power. Best I ran was 11.6 before so hopefully it'll get even better
I was at the Borg-Warner KKK factory this week as you know. I infact took your turbo cartridge. They actually wanted to throw them in the test cell. Unfortunately they would most likely wreck them. I learned alot and seen quite a few new trick for our cars.
Another interesting note. KKK has not choosen to go down the ball bearing road. However, the engineers have told me a few trick to equal the playing field for our units. Basically the ball bearing units have a advantage by keeping the centerline of the turbine shaft stable. Thus the clearance between the wheel and aluminum housing can be tighten to .006", With my cnc'd housings I can come close but not near .006. The solution that they are working on is to coat the inside of the compressor housing to build up the clearance. Hence, you improve the efficiency of the unit. Now as the unit's bearings wear the coating wears to provide extra clearance. It's also a tattle tail sign when to go in for a rebuild! Mark my word, We will be coating the insides of the housings!!!!
That must have been a lot of fun Can't wait to hear about them tricks!
Originally posted by Kevin Another interesting note. KKK has not choosen to go down the ball bearing road. However, the engineers have told me a few trick to equal the playing field for our units. Basically the ball bearing units have a advantage by keeping the centerline of the turbine shaft stable. Thus the clearance between the wheel and aluminum housing can be tighten to .006", With my cnc'd housings I can come close but not near .006. The solution that they are working on is to coat the inside of the compressor housing to build up the clearance. Hence, you improve the efficiency of the unit. Now as the unit's bearings wear the coating wears to provide extra clearance. It's also a tattle tail sign when to go in for a rebuild! Mark my word, We will be coating the insides of the housings!!!!
Yeah some of my friends with Supras swear by the new beefy ball bearing Garrett turbos. I guess the smaller ones wil work well on our cars too, well not on the tiptronic... Your solution of coating the inside of the housins sounds cool but hard to do no?
