Tiptronic in a TT?
#32
Haywood ran in the GT class for the Grand Am Rolex series and since the car was GT3 cup car, they are only standard. Maybe his private car. Be he said, he used the trip for safety reason leaving both hands on the wheel, and he was a proponent of leaving the trip shift by itself. Not sure that's such a great endorsement.
As for Hurley's personal Tip Turbo, he loved it, and recommended it for everyone in all uses of the car, street or track. He did many DEs and track PR events with it and he used it many modes. Sometimes he left it in full automated, sometimes he used the buttons and sometimes he would trigger downshifts by stabbing the gas pedal to hit the kick down button. He was a nut with it.
The clutch pedal is becoming obsolete, the Tip Turbo was a first step in its exstiction.
Sorry to get so detailed with all this. I did my research before I bought my Tip. I also grew up racing karts so getting back to two pedals is like meeting up with old girlfriend. She just has 430+ HP now.
#34
Did not say unit was an H pattern, still is considered manual under race rules. PDK by design are not automatics as the tip is. It is a dual clutch system as compared to the torque convertor coupled automatic tip which btw has a lag in between shifts, even with updated software. With that said PDK is in a world of its own and is not in the same league as a tip.
#38
#39
This thread cracks me up, especially the comments how the tip is bad but BOY YOU SHOULD TRY THE PDK, IT'S IN ANOTHER CLASS. hahahahahah. The main argument against tip everybody seems to be making is that it takes away from driver involvement. How is the PDK any different? What, it changes gears 1/10 of a second faster than tip and that makes it the be all end all? I know PDK is great, but to come here and belittle the tip but praise the PDK just makes no sense. I drove the tip and MT before buying the tip and I love it. Put it in M mode and you can keep both hands on the wheel while shifting through some crazy turns that are a blast to drive. Anybody that says tip sucks but praises the PDK is talking out of both sides of their mouth. Buy the tip and enjoy!!!!
#41
I don't disagree that a PDK is better than the Tip. There are also different models PDKs in different model Porsches out there. The one in the new GT3 is highly regarded but I have had people tell me the first PDKs in the 997 models were not the great improvement over the Tip they had hoped for.
Also on F1 cars today they employ a device known as "seamless shift" in their dual clutch gearbox and what it does is very similar to what a torque converter does. It smooths out the power peaks going from the engine through the gear box when shifting. It allows them to shift while in a full cornering drift without unbalancing the car. There are some good things going on in that Tip trans.
#42
We are talking about a Tip vs an H pattern manual. Maybe you should go back reread this thread because you have missed something and don't think this the first time.
#43
yes.. WE were.
NO.. i'm not.
umm, what's that? lol "don't think this the first time!? is this some kind of a riddle?
NO.. i'm not.
#44
Nuclearfishin it's obvious you haven't driven a PDF until you do then you will understand. There is no comparison in shift time direct coupling providing instant power to the wheels and has to be driven different than the trip. Before you go making some comparisons I suggest you really drive one.
#45
Carlos you are kidding a torque converter simulation in an f1. Think some research on your behalf is warranted. The f1 sequential trans use clutches which are hydraulically controlled by ecu. If you understand a torque converter you would know that hydraulic fluid is used as a fluid coupler using turbine action.
Of which there is no direct power transmission. The f1 uses clutch timing to control the peaks you talk of
Simply put mechanically you can't say it sort of works like a torque converter. That just doesn't make sense.
