Water Pump
The water pump went out today. Fortunately, I was only 1 block from the house. Unfortunately, my CPO expired 6 weeks ago.
Two questions... Is it a DIY or does the engine need to be dropped? I can clearly see it with the air box removed and it's slinging coolant everywhere and emitting a definite squealing.
If the engine needs to be dropped, is there anything else I should do while it's out?
Bill Farrell (08-14-2024)
I had my indi do my WP; it's a bit different on the Turbo than the NA 996 . the main crossmember that runs across the rear has very little clearance to be able to remove the WP. My indi indicated that the engine would have to be lowered just enough to allow the WP R&R. Im sure you can DIY with proper ramps and jack set up. then you also have to flush and refill the coolant and purge the residual air.
IIRC, the Turbo WP gasket I rec'd from Suncoast was a thin metal, unlike the video. IMO, I don't think you need all that RTV on the gasket as the video shows.
Well I have company all weekend, I will be traveling all next week, and we are headed to the Bayhouse next weekend.
Taking the easy way out and sending it to the indie on Monday. I'll have the coolant lines pinned while they have it.
when I had my engine dropped, I had them do the following
pinned pipes
lwfw
clutch
GT2 conversion
H2O pump
coolant tank
plugs
coil packs
all new hoses
997 transmission mount
WEVO engine mounts
pinned pipes
lwfw
clutch
GT2 conversion
H2O pump
coolant tank
plugs
coil packs
all new hoses
WEVO engine mounts
It's worth a phone call to your dealer, especially if you have a good relationship with them. They might be able to get Porsche to goodwill the repair for you since it's so close to the CPO expiration. Worst they can say is no, then you're right back here anyway. Maybe you'll get lucky since the water pump failure is a known issue.
The good news is that I picked it up today when I got back in town.
At any rate, glad to have it back in the stable.
Do know how far the engine had to be dropped ad how involved it was to do?
