997GT3 Shifter "SALE"
#47
Here is Sonnen link. Look at the upper right corner..
https://sonnenporscheoemparts.com/pa...?SiteID=215405
You can call Greg, Neil or Gina in parts 866.Sonnen1
Two weeks ago there was one shifter in stock.
#50
Took mine out for the first time yesterday. Wow, way better than stock! Is it $400 better than stock? probably not. But it is a subtlety nicer with slightly crisper and shorter throws. I could use it a bit shorter (I know 997ssk) but overall very nice.
Also, FYI, mark your oem thread points where they go to the OEM shifter before removing. In my excitement I just pulled everything apart, and then realized what I did. But I think I have it dialed back in pretty close, if not better than it was originally setup.
#52
I used the alignment tool that came with it as a reference (once I realized that I had screwed up and didn't mark the cables originally), but wasn't pleased entirely with all the shift points of it by using just the tool. So I adjusted slightly from that point until I felt like all the gears engaged smoothly.
#53
