spoiler failure
I visited the site and found the wing setup you are referring too. Yes, it is listed for under $2500, though this does not include the final paint. Not sure what this would cost.
For less than $2500 -- and no visit to the paint shop -- I can have the stock system replaced with a factory new one.
Which is probably what I'll do when I get around to it.
I dropped the car off today at the dealer and they are overnighting parts for Monday. Since it is still under warranty I will go with the $0 repair option. I do appreciate the many suggestions and will let you know what all they replace. I hope the warranty does go for 2 years from repair since the CPO expires in April 2014.
I picked the car up from the local P dealer and they replaced the entire system under warranty. They said that it is sealed from Porsche and very difficult to replace individual components once it has begun to leak. Interestingly, the warranty expires with the end of my CPO in April 2014. If the car was out of warranty I would get 2 years from the date of repair? Oh well, all fixed for $0 dollars and I got to drive a lovely baby blue metallic Hyundai for a few days.......
The job can't be done on a fixed number of hours it takes what it takes. At $150/hour labor for say 4 hours that's $600 plus another $600 or more for parts, and fluid, plus incidentals, thus one is up to an easy $1300 or more and the thing could leak again tomorrow.
And while it seems some owners who advise going the fix it yourself route or have an indy shop fix it route are quite willing to risk having the unit fail again after a while are not so willing to forgive if a dealer service department fixes it and the fix fails after a while.Then these owners want that 2 year warranty.
Thus the dealer service department is on the hook for the parts and labor warranty, which means in the end the dealer has to buy and install at its expense a new spoiler mechanism.
OTOH with a factory spoiler installed if there's a problem PCNA covers not only the parts but labor so the dealer (or the customer) are not out the expense of having to repair the spoiler again.
Replacing the entire sytem is pretty easy. You can replace the individual components, but the bleeding is no easy task since the entire system uses a very low volume of fluid.
Replacing the entire system anyone can do. There is no risk. It comes out and goes in very easy.
I don't think that is correct. Any repair/replacement of a malfunctioning part (like the spoiler) performed by Porsche should get a 2 year warranty from date of repair. So, for instance, if it fails again 23 months from now, you should be covered regardless of CPO expiration.
"2-year warranty for genuine Porsche parts, exchange parts and accessories, which are used or sold outside of warranty work. The warranty period for Porsche parts which are used in connection with warranty work ends contemporaneously with the warranty period for the purchased item which has become defective"
Real cute. So, if I buy a spoiler, it gets a two year warranty. But, if they install a spoiler under warranty, limited to duration of warranty. Oh well, I got one "free" and its lasted about two years so far....
