Actuator seized.
Porsche offer a free health check of the car once a year, as a way of drumming up business. You get to see your car up on the ramp and ask the tech' any questions you might have. During mine today, he showed me that one of my mine is seized. He showed me how it is threaded, but if it can't come off the turbo, I need a new turbo too? Anyone had this?
Quite pleased if this is the only thing wrong after 3000 miles in 8 days.
Good ol acid rain, and just damp weather rusting the turbocharger. You will need to replace one turbocharger. The shaft for the gate that connects to the actuator freezes from corrosion.
So, is it the actuator that is seized, or the shaft for the gate? The technician thought it might come out, but said he had encountered a few that had to be replaced as complete items?
Sorry, just re-read that it's not what I meant to ask. Sorry, what I meant is what's the most common part to seize? The actuator or the shaft?
Thank you.
Thank you.
I'm having a hard time envisioning what you're describing, but would a product like PB Blaster or Kroil help in loosening the seized actuator?
Otherwise, maybe have your stock K24's sent off to a turbo-rebuilder. I see you're in Scotland, but over here we have shops like Blouch that will rebuild/refurbish turbochargers... you could even have them upgraded into a K24 Billet-wheel turbo, if you wished.
Alternatively, if you need a new turbo, watch the forum classifieds here and at 6speed - you see stock K24's come up for sale somewhat regularly, at a much more reasonable price than a brand new replacement part from the dealer.
Good luck! Keep us posted on how it goes.
Angelus, the actuators rarely fail. The turbine gate does fail. Corrosion welds the shaft to the internal bushing.
If you want to see if your actuator still works unbolt it from the compressor housing (2 10mm bolts) Apply some air to the actuator. If the rod move outward it is functioning correctly.
Thanks Kevin, I'll give it a try before I go ahead and change it. I'm trying to find a replacement turbo to put on, but I'm having difficulty. If anyone sees one, please let me know. I thought I'd struck lucky and found someone selling new ones in the UK.
http://www.carparts911.co.uk/turbocharger
I thought there was a zero missing from the price and I'd found a bargain, but after phoning them, they said it was an original Porshce part and gave me the part number. It was for the diverter valve? New from Porsche today, they are £3000.
Having put the car on a ramp this morning and looked at it, I'm still confused. The gate was stiff, however a bit of movement and it freed off. Some non flammable penetrating fluid was applied and it freed right off. It all seems to work the way it should on both sides. It has not made a difference to the performance of the car though? I'm still getting 1.1 bar boost and it runs fine. The boost disappears when you lift and it spools up quickly when I floor it? How is the system supposed to work? What should have been the difference from freeing off the actuator?
Sounds like everything's fine for now... I'd just keep an eye on it.
Since this is just one actuator the bad side turbo may be making a lot more boost.
All of the above of course assuming my well, assumptions are correct on what the actuator that is siezed is supposed to do: limit boost.
Sincerely,
Macster.
