Do you know these codes?
Check engine light came on after a 4 minute warm up and a 2mile drive to the soccer fields this morning. These are the codes it's throwing off:
- PO491: secondary air injection system
- PO492: secondary air injection system
I have the "996 Turbo vacuum system" diagram. Do i just sort of nose around and look for something out of sorts?
Seems like a lot of folks run into these codes from a quick Google search.
Secondary Air Injection System, Bank 1 & 2 – Below Limit
Possible fault cause
♦ Secondary air injection pump is not triggered
♦ Secondary air injection pump does not work
♦ Air supply lines restricted
♦ Electric change-over valve does not function
♦ Air change-over valve does not function
♦ Vacuum system leaking
Yep, I'd guess vacuum system leak
I had those codes, cracked valve
What he was asking was 'did you hear a honking noise when you accelerated hard- such that the boost gauge was showing boost?'
When a diverter valve fails, the internal rubber diaphragm ruptures and under boost this flaps about causing a 'honk'...think whoppee cushion like.
$340? Hmmm. And a stock replacement? Only one? First thing I did was prophylactic replacement with aftermarkets- both of them.
