Durametric software question
I hooked up the Durametric cable and was going to play around with the instrument cluster on a 2001 996 turbo. First, I couldn't get anything to test. fuel wouldn't go from 1/2 to full, Temp would not respond. Second, when I quit the program and disconnected the cable the turbo boost readout was gone. I can't get it on the bottom readout or the top readout. When I go to the top readout, it isn't even one of the display options. Anybody have any ideas?
Joel
Joel
Joel
Joel
But there are those here that have used the Durametric tool and if there is a way I'm sure someone will chip in with that info.
In the meantime, my only idea is the big red switch idea.
For you and your Turbo this means disconnecting the battery for a while. Be sure -- if you elect to do this -- you follow the proper steps for disconnecting the battery.
Before you disconnect the battery note the radio's security code if it has one.
So there is no chance of trying to start the engine or even leaving the ignition key on, be sure the ignition key is removed from the ignition switch.
To ensure all residual power is gone you can press on the brake pedal which is a safe way to ensure residual power is gone.
Then reconnect the battery (following proper instructions) and see if this helps.
Sincerely,
Macster.
I tried the reboot, battery disconnect. same as before. And yes JP, I was messing with the many bugs, still in beta version 6. I contacted Durametric and sent them a logging of the problem. I will post if they have any answers.
Joel
Joel
Have you upgraded to the absolute newest version of the beta? I had issues with the beta that was released earlier this year, but since upgrading haven't had any issues.
I had the problem with the second to the last upgrade, so i upgraded to the latest and greatest. I still have the same problem. Just got an e-mail from Durametric, they said to try the K21 instrument cluster instead of the K01. My guess is that Porsche upgraded the turbo instrument cluster before the non turbo in 2001. I tried the K21 and was able to communicate and activate.
Still no Boost pressure gauge on the cluster. any ideas?
Joel
Joel
