Dension install and radio help please
I just installed the Denison GW500 with my PCMII + CD changer combo system. One thing I would advise when configuring the menu for text display is to look at the display on the PCMII for the correct submenu/option rather than following the instructions in the Denison manual. It appears that the software has been updated and the instructions in the technical manual are no longer accurate.
I have a couple of questions, however: In IPOD mode, when selecting track or song, I use the right **** to scroll through the menu. However, if I scroll down the list to a particular track but do not press select on the control ****, the song is still selected. I do not know if I made an error in the configuration between the "paging" function and the "select" function? Can anyone advise? Should I update my software? I am using an IPOD Touch.
At least mine doesn't.
