Diverter Valve?
TY! Looks like one of those pita jobs that takes 2 hours longer than it should...just went through one of those projects while replacing my b-pillar seat belt deco covers. 1st one took 1 hr...2nd 15 mins.
No maintenance on the Bailey's ?
Here is a fantastic post about the Bosch 710A (Stock) and the 710N (Upgrade DV)
http://www.6speedonline.com/forums/9...er-valves.html
Basic Sponsor
I have the Bailey's and prefer them to the Bosch. I installed Baileys when I purchased my car in '02. While tuning it a year or so ago, we found they were leaking (7 years/90,000 miles). I put 710's on and sent the Baileys out under warranty. The car ran fine, but seemed a little different. When the Baileys came back (they sent me a new set), I installed them. After the Baileys were re-installed, my car returned to normal again..the difference is the Baileys make a noise when they vent and the Bosch did not. It was a noise I was used to and something was missing with the 710's. The Baileys sound better...
991.2 GT3 RS Weissach Racing Yellow
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
former 1972 911T white, 1984 911 3.2 Targa black, 993 cab white, 993TT arena red, 993TT silver, 996TT speed yellow, 991.1 GT3 white
www.speedtechexhausts.com
info@speedtechexhausts.com
Testimonials SpeedTech Exhaust Videos facebook
2022 Cayenne White
I got these from Alex at Sharkwerks. I was amazed at how much better quality these were in comparison to the OEM ones.
Eugene
http://www.sharkwerks.com/products.php?pid=30
Eugene
Got the 2003 996TT a few months ago. Stock, which gives me plenty to upgrade.
I researched DVs looking for technical evaluations instead of vendor claims. The write-up linked to on 6speed was well done.
Bottom line for me was when either type fails you have to get to them. With one, you throw away the old and replace because they're expendable. The other (depending on the failure mode, seal failure versus dirt/debris versus lubrication) you fix yourself and reinstall or ship off and await replacement. Since the labor is the same I went with the expendable upgrade.
There is no right or wrong here, just what works best for your priorities.
the bailey are maintenance free and lifetime warranty. you are making a purchase by future replacement or problems. I have never heard of a bailey "failure". like any thing I'm sure they are some if so the are extremely rare.
throttle off and on between shifts are noticeably crisp with the baileys.
like I said it's a job you want to do once
good idea to change out the F pipe while your at it.
When the 996 Turbo first came out it was common for the OEM DVs to have problems. There were many threads about bad DVs and what brand to replace them with. Porsche eventually stepped up to the plate and installed improved DVs, but during the times prior to the fix, Baileys were the go-to replacement DV...because they were (are) so good. They were the DV to have; and IMO they still are.
