996 Turbo Forum 1999-2005
Stock Intake or AfterMarket (Fabspeed)
Old 01-19-2011 | 06:22 PM
TachiF's Avatar
TachiF
Default Stock Intake or AfterMarket (Fabspeed)
Hi Guys, need some advice/opinion:
I bought my car with both, Intake & Exhaust Fabspeed already installed. Looks like the Engine will performs better with the Original Stock Intake box rather than with my aftermarket, Fabspeed Intake. I was told to replace my aftermarket with stock ones.... IM DOING SO....
PLEASE give me Ur Advice/Opinion.....
Old 01-19-2011 | 10:08 PM
Macster's Avatar
Macster
You received the advice to replace the aftermarket intake with the stock one and by someone who claimed the stock intake would perform better than the aftermarket intake and you must have some trust in what this person told you cause you're doing the changeover.
About all I can add to this advice -- and my hunch is it is good advice -- is make sure you do the aftermarket intake to stock intake switchover correctly and then drive the car. Alot.
Sincerely,
Macster.
Old 01-19-2011 | 11:57 PM
dantzig's Avatar
dantzig
My advice would be to get a Durametric and log data before and after the changeover. Data don't lie.
Jon
Old 01-20-2011 | 02:12 AM
jbossolo's Avatar
jbossolo
If the advise came from Kevin do like Nike: "Just do it".
Old 01-20-2011 | 02:35 AM
Kevin's Avatar
Kevin
He is running the exposed flat panel intake. It is sucking all the engine heat with ZERO cold air entering the MAF...
Old 01-20-2011 | 10:26 AM
911SLOW's Avatar
911SLOW
Admin
You are doing the right thing.
Old 01-20-2011 | 11:51 AM
RxPorsche's Avatar
RxPorsche
Hey Kevin, How about an agency power intake? Do you also recommend to change to the stock one?
Thanks.
Old 01-20-2011 | 01:46 PM
jbossolo's Avatar
jbossolo
^That's the one I'm running.
Yep, that design doesn't make any sense at all.
Old 01-20-2011 | 02:06 PM
Kevinmacd's Avatar
Kevinmacd
Agency power also makes a retrofit kit that uses the back of the original airfilter housing, adds another intake for a total of two, called dual flow. They use the original filter size. No inside air drawn in. They have three versions starting @$450
http://www.agency-power.com/catalog/...pufsc8sa7iqk33
Old 01-20-2011 | 02:22 PM
tvurt's Avatar
tvurt
Keep it if you have big turbos / with inlet pipes, if not it is doing more harm then good. This works well with a GT2 tail that has been modified to open both sides.
Old 01-20-2011 | 03:48 PM
LVDell's Avatar
LVDell
Looks like somebody built that in their garage one afternoon.
Old 01-20-2011 | 04:39 PM
Kevin's Avatar
Kevin
Best advice is to keep your stock intake.. If you have large turbochargers I do have a solution but already have large injectors and are making over 600 wheel HP..
Go look at the factory 997TT. Cold air has to enter the airbox. You can mimic the 997TT airbox by cutting a extra hole in the factory box. However, you need to fabricate another duct from your rear wing to the box. You CANNOT have engine heat migrating into the airbox.
There are very little gains with aftermarket filters > stay with the Mahle original filter element! If you want to have more power>torque> change your turbocharger inlet pipes/ducts.
Old 01-20-2011 | 06:29 PM
TachiF's Avatar
TachiF
Kevin, then U suggest to keep the stock intake WITH STOCK ELEMENT as well? how about stock intake with K&N Element? NO GAIN/Unnecessary ??
Kevin: stock intake allready back in place !!!
Old 01-20-2011 | 06:32 PM
earl3's Avatar
earl3
K&N = no gain and potentially toasted MAF sensor, stick with stock
Old 01-20-2011 | 06:44 PM
Kevin's Avatar
Kevin
To clarify.. Do not use K&N or BMC oil filters.. Use the stock Porsche (made by Mahle) air filter.
The factory Mahle filter is very good, it is very large with alot of surface area.
Quick Reply: Stock Intake or AfterMarket (Fabspeed)
