996 Turbo Forum 1999-2005
Turbo on track at VIR....impressions
Old 11-30-2010, 06:56 PM
  #31
ScottArizona
ScottArizona's Avatar
Originally Posted by TT Surgeon
Stick to your guns Dell, 209 is damn respectable with a real DD. Once you start really getting after the suspension it never ends, then it's just a so so track car and a miserable street ride. I would consider a set of adj gt2 sways, and that's it!
Chris/Dell: don't you need adjustable drop links too if you are going to run ARB's? Those are pricey too!
Old 12-01-2010, 08:02 AM
  #32
LVDell
LVDell's Avatar
In the grand scheme of things not much at all. About $450 for F&R from Tarret.
Old 12-01-2010, 04:14 PM
  #33
Mikelly
Mikelly's Avatar
Dell you need to get the drop links from TRG. They're more expensive, but are curved to clear the front axles... Just sayin'
Mike
Old 12-01-2010, 04:18 PM
  #34
LVDell
LVDell's Avatar
Is it your goal to part me with ALL my money?
On a serious note, since I am not familiar with what I have on right now (stock), are they curved as well? Just trying to understand. Thanks Mike!
Old 12-01-2010, 05:11 PM
  #35
Tytus
Tytus's Avatar
Originally Posted by LVDell
245/40/18 (moving to 235/40/18 next since the 245's were VERY close to rubbing)
315/30/18
No rubbing.
Are these sizes ok with the AWD? I thought you couldn't deviate from stock due to possible diff damage.
Tytus
Old 12-01-2010, 05:14 PM
  #36
LVDell
LVDell's Avatar
There is a tolerance between front and rear that you should stay between of 3%. Their diameters are well within that at:
25.39" for the 235
25.55" for the 245
25.35" for the 315
Old 12-01-2010, 07:49 PM
  #37
Mikelly
Mikelly's Avatar
Stockers aren't curved, but def. pencil thin and will break on you, especially the way you drive, Dell. I've broken TWO in the first year I owned my car... one front, one rear... I run the Tarreds on the rear and the TRGs up front... They're BEEFY.
Mike
Old 12-02-2010, 10:32 AM
  #38
LVDell
LVDell's Avatar
Great, you just got me another grand.
Old 12-02-2010, 01:57 PM
  #39
ScottArizona
Mike
That's strange that Tarrett would put out the front links in a straight (non-curved) configuration, if curved is requried. Do any other manufacturers use a curved link?
Old 12-02-2010, 03:28 PM
  #40
LVDell
LVDell's Avatar
Do we know if Tarret's are straight or curved for the front?
Old 12-02-2010, 04:13 PM
  #41
Oak
Oak's Avatar
straight
Old 12-02-2010, 04:18 PM
  #42
LVDell
LVDell's Avatar
Interesting. I wonder why.
Old 12-02-2010, 04:30 PM
  #43
Oak
Oak's Avatar
orginally they were designed for the 996 2wd. prior to my motons I had the trg straight version and I didn't have any issues with rubbing. if I remember correctly I had adjusted them full loose with GT sways, with so much understeer I doubt you would set them any tighter atleast for me. If the length is adjusted with the suspension unweighted so the axle is at the most positve camber you shouldn't have any rubbing issues. my suspension was lowered also..
Old 12-02-2010, 04:33 PM
  #44
LVDell
LVDell's Avatar
Great, thanks for the explanation.
Since I am not an expert at metallurgy I am curious if the beefy bent units from TRG are less or more strong since they not straight. I would assume straight is stronger?
Old 12-02-2010, 05:56 PM
  #45
Oak
Oak's Avatar
not sure about strength but I would think that the straight version would be harder to flex. the trg straight version I had were top notch, If I remember they were the most pricey also..
Quick Reply: Turbo on track at VIR....impressions
