error code P1325
Not sure what you found out with your motor Joel, but we pulled the motor apart to see what was going on with our P1325 code. At 90k miles, this motor is well.....disintegrating, lol.
Front cam housing grooved:
3 tappets on the passenger side shot, 1 on the drivers
Inner part of the tappet has been chewed to oblivion.
I'll take a better picture that shows the cracks, but both front cam brackets are badly cracking, looks like they are matched to the main cam housings, so both will likely have to be replaced.
Karl is there metal in the oil filter? How does the exhaust cam/thrust/shoulder look. I have customer that is having a chronic right bank misfire/with a metalic noise.. All the usual parts have been replaced. I have a feeling that we have a few failed tappets..
Guys I can LOCK your tappets (with programming) in the closed position to reduce this failure.
I'll take some pictures of the various components of the engine when I am in the garage this afternoon and post them up.
Was bone stock until about a year ago when he picked up some used modified K16's and programming. He has run with as straight out exhaust for quite some time now though. While the car has been run hard at the track, I don't feel that he "beats" on it.
I'm going to do a little RANT>>> Porsche executives read these threads but they don't offer any solutions. Either on the forum or in private emails. I have torn apart 3 engines with faulty intake tappets >> they FALL apart when you remove the intake camshafts. I have had three customers within the last 3 years require all the lifters and camhousing on one bank replaced. One customer had to replace his head (valve guide got worn beyond spec) I actually received the head for inspection.
Right now we have Doc's engine and Joel's engine along with a customer who I think is near to having his engine removed.
Karl, the metal HAS to go thru the engine. Did this engine have a DUAL MASS flywheel? Guys>> Dual Mass flywheels and the track are NOT good! We are seeing accelerated crankshaft thrust bearing wear. This was reported years ago.
This issue is NOT just contained to the 996TT engine, the 997.1TT will see it also.
Guys change your oil more often, inspect your oil filter and replace the filter at 1/2 your oil change interval. My recommendations are at 5000 miles and more often if you track your car. Filters can be changed at 2500 miles.
Like I mentioned in my previous thread, I offer to my customers that ability to LOCK the intake tappets. There is very little performance LOSS, I can spool the turbochargers quicker and give you back the torque loss in spades. By locking the tappets we reduce the strain on the hydraulic lifters and reduce the failure rates.
Did someone said the GT1 block was bulletproof
Kevin the coolant pipes problems still exist today on newer models, 997, GT3 etc, I am really wondering if Porsche executives really read these threads.... Do they really care
I read where Porsche 'tested' this to 250,000 cycles but I do not know what this number means in real world driving, how many miles this 250K cycles represents if the car/engine is subjected to normal (whatever that is) use.
As an aside, my 02 Boxster's passenger side VarioCam solenoid and actuator were replaced (the engine generated a P1341 error code and exhibited symptoms that pointed very strongly at the solenoid/actuator) at around the 239K mile mark. I believe the solenoid/actuator are activated at idle to about 1400 rpms (or when rpms drop to below 1400) and reactivated again when rpms climb to something a bit over 5K rpms.
There may be exceptions related to engine coolant or oil temperature, load, and so on.
(As a further afield aside just the solenoid was replaced but the engine generated the same error code and symptoms shortly after I got the car back. The problem was traced to the VarioCam actuator which was then replaced. For reasons I won't go into now I was not charged for the duplicate labor (and parts) to disassemble the engine (the engine remained in the car) back to the solenoid stage, but I was charged the extra parts cost (actuator: approx. $800) and labor (approx. 5 additional hours -- the cams have to come out and of course be reinstalled with the correct timing) to R&R the actuator.)
Sincerely,
Macster.
The 996 Turbo engine block is (nearly) bulletproof but unfortunately the internals are not.
(My 02 Boxster's original engine has covered just under 240K miles and while the block is in apparently good shape still (thank goodness!) I just had to have the passenger side VarioCam solenoid and actuator replaced [a $3K job]).
Sincerely,
Macster.
Sincerely,
Macster.
We changed oil after every event in this engine, and usually before the event depending on how much street driving he had done in between. Unfortunately, it went many years on 0-40 before I switched him to 5-40. I cut the filter open this afternoon, and again, no particles. I'll post up some better pictures later this afternoon once I get a few other cars on their way.
jp > Did you see my RANT's in the previous oil thread?? Can I say Mobil 1 5W40 TDT.. Can I say, change your oil sooner!
Macster, Yes, I know what the operating conditions are > the mapping is based off load vs RPM.
jp, they read these threads.. However, I feel that they should offer some Goodwill to some of they folks with parts discounts to get there engine back to whole.
1) IMS problems
2) Camshaft chain breakage
3) Inlet tappet failures
4) Vario cam module failures and sealing ring failures
5) Coolant nipples "glue" failures
6) Premature radiator failures
7) 2nd gear popouts
EDIT
8) Beru FR5 spark plugs > misfires
9) Beru Coil Pack, #1 and #4 take a beating from the heat and misfire
This is a good list to grab there attention.
1) IMS problems
7) 2nd gear popouts
EDIT
1) IMS problems
7) 2nd gear popouts
1) IMS problems
7) 2nd gear popouts
