This will Ruin your day and Engine
Log rpm, injection time and O2 sensor lambda values. AFR = lambda*14.7, and duty cycle (%) = (inj time)*(rpm)/1200.
While you are there, you might as well log engine load, MAF, air temp, ignition angle, boost pressure, boost pressure setpoint too.
Jon
Jon
This is my old list from Kevin:
RPM
Engine Load
Mass Air Flow
Air intake temp
ignition angle
injection time
oxygen sensing bank 1 lamda value
oxygen sensing bank 2 lamda value
boost pressure of sensor
setpoint boost pressure
boost pressure control P/D factor
correction factor for b/c w/ knock control
RPM
Engine Load
Mass Air Flow
Air intake temp
ignition angle
injection time
Wow Kevin im glad you got ahold of that motor and not me as i was trying to buy it when he called you that morning=)
i wondered how bad it was because i knew what could happen.
Im interested in your datalog tool.
William,
William,
William, I think that your money was better staying in the Bank vs getting this motor. You most likely would have been disappointed. I'll put you on the datalog tool "list" Thanks..
i agree i have my eye on two other motor but car should be apart by next week, hoping to get out of it witha new gasket and decking the heads while i build a spare block on my time. at this point i just wanna drive it stock motor would be fine even =)
Thanks for the info Kevin
Puma, price will be the same.. Worth buying>> faster logging, more values, individual knock (this alone is worth the price) Do you remember your failing fuel pump ordeal? Knock is key to preventing these engine failures.
do you mean there is a knock sensor for every cylinder? Or is the program going to be able to interpret at which cylinder the knock is coming from?
can't wait to see what it will look like.
The engine has one Bosch knock sensor per bank. With the crank sensor and each camshaft sensor the ECU knows which cylinder is firing thus giving us Individual Knock resolution.
nice, that is great, is your program going to be limited to a couple of cars (VIN) like the durametric or will it be free of use? What type of cars is it going to be working on?
