GT2 Slave Conversion wear the clutch faster?
Joe that won't be a good indication. The reinforced pressure plate and LWFW is stiffer. Remember the GT2 uses a dual mass flywheel and a stock turbo pressure plate.
Okay that makes sense. Certainly there has to be a factory car out there with similar clutch stiffness? A Ford mustang? Lamborghini Diablo? I will go clutch whoring around the city if I have to.
I drive mine in rush hour traffic all the time. EVOMS conversion. Stock flywheel and sachs stage 4/cluchmasters clutch.
Amazing upgrade. The clutch bites at exactly the same point now. It is a bit stiff, but only in comparison with the stock mushy unit.
Kinda a DD, about 3 days a week March - November. Even tho the pedal is harder to push, the GT2 slave mod made the car a BETTER DD, as it is easy to feel your engagement on hills and in stop and go.
It's all about air flow efficiency and cooler air temps... The intake piping and the stock intercoolers are probably the most overlooked "upgrades" in the system...
And they're still not done on mine either... Although Mine came with GT2 units... they're still not very efficient.
Mike
Mike
Intercoolers are definitely worth upgrading, IMO. But I think it depends on how you use your car. For track sessions, where you are into the boost for 20-30 minutes, they definitely will heat soak. When I was logging data, I saw that after 3-4 pulls the inlet air temps went up a couple of degrees. So for occasional spirited street driving, stock intercoolers are probably ok too. This is an easy one to test - hook up your durametric and drive the way you think will be the most taxing, and log the inlet air temps.
Jon
Agreed, by its self very little to no gain, but as I said while the engine was out that would be the time to change the piping to save the labor of dropping the engine. Evoms seemed reasonable for parts however without larger intercoolers and intake piping/TB & plenum to see increased air flow for moddest 20 - 30 gains was shown on the other forum.
Its not just the gain, of "only" 20-30 hp, it is the shift of the turbo spool a 100-200 rpms lower. I would do the pipes if you are at the K24/18g / billet K16 / A28 level or higher.
John D at speedtech is running a special on a new intake plenum and hard pipes right now.
yea thats why I said moddest, I didn't want the "show me the dyno". bcz it depends on your complete set up, I'm running Alpha's 3071's, did the intercoolers and had the chance to do the piping but didn't know enough at the time. There will be soon I hope so I can finish, if there is ever such a thing ha!
I have seen several installs where the intake pipes were done with the engine in place. You have to cut the factory pipes with a saw and install intake pipes that are split with a coupler in the middle.
Really wish Kevin would chime in here...
The reason you want to do it has nothing to do with "added" power, but making the motor work more efficiently while reducing the stress on the motor... For those of us tracking this is the smartest money I think you can spend to make that long block and turbos live a happy and fruitful life!
Mike
Mike
Adding a side/rear plenum kit that increases the diameter of your turbo inlet piping will reduce the backpressure to the turbochargers. You hear of guys bolting on GT3071's and 20G's with stock plastic piping. It's like using a coffee stir straw to drink your Coke.
The main benifit is spooling up the turbochargers "quicker" >> anytime that you have lag reduction you will build MORE engine torque sooner. You really won't see more PEAK HP due to the boost staying the same. You will see your torque curve moving to the LEFT up to 500RPM's.
