Noise from light weight Fly wheel
5th Gear
Hey i purchased a 2002 996 tt and the car came with some mods, it has a lighten flywheel and it is making some noise more like a grind or rattle but when you press in the clutch it go's away... i had to replace the clutch as the slave was leaking and i thought the clutch had gone bad ( started to slip).. When you first start the car i the morning you can barely hear it but when it warms up it really starts to rattle.sound like the gears are grinding....i was told that the light flywheel does this but i want to know why..
can anyone who has one on there car tell me if there's make the same noise?
Thanks in advance
Manny Sanchez
WOW Mobile dist.
Get free cell service, Ask me how![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
wowmobilemanny@gmail.com
Thanks in advance
Manny Sanchez
WOW Mobile dist.
Manny, I have a N/A 996 with the Aasco light weight flywheel. It makes the same exact noise. It increases when the car is warm or the A/C is on. I was warned about the noise, prior to having the LWFW installed. The stock flywheel (dual mass) absorbs the noise. The slight noise is a minor irritation, but well worth the increased performance.
5th Gear
thank for the info... i still don't understand what is the noise ,, it the flywheel moving on the input shaft ? why does it make more noise when it warmd up?
i guess i will have to live with it ... i will endure the sound for the extra get up and Go...
Thanks in advance
Manny Sanchez
WOW Mobile dist.
Thanks in advance
Manny Sanchez
WOW Mobile dist.
Not sure if the LWFW can also cause the gear drive between the crankshaft and the layshaft to rattle as well.
Sincerely,
Macster.
5th Gear
Thanks guys for all the info,,, i think i can live with it... i like the performance
a little sound,, lots of get up and go..![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
Manny Sanchez
2002 996 tt
Wow Mobile
free cell service, ask me How?
enjoyfreewireless.com
Manny Sanchez
2002 996 tt
Wow Mobile
The dual mass flywheel serves to dampen the gear vibrations in the transmission. With a LWFW, you'll hear the gears rattling when in neutral, with warm gearbox oil. It can be particularly noticeable if you are sitting next to a wall that reflects the sound. When you push in the clutch pedal, you are disconnecting the geartrain from the engine/FW and thus not exciting the gears to vibrate/rattle. It's all par for the course with a LWFW.
Cheers,
Cheers,
