Battery Charger/Maintainer
Mine is the same as "wross996tt." Order the quick disconnect pig tail for the battery, attach the leads one to each terminal, then connect the charger "quick-connect" plug to the the one on the pig tail.
You can run the charger lead through the opening at the top right side of the hood while the hood is closed and latched. Just plug the charger in, set the appropriate cycle, and you are good to go.
Easy disconnect whenever you are ready.
If you order the CTek charger/maintainer (you can find it on Amazon.com), you'll see it offered as one of the accessories. There's probably one available for the Battery Tender Plus as well.
